how do I remove the antenna
Old May 20, 2008 | 01:56 AM
RoboX's Avatar
Default how do I remove the antenna
I was wondering how you remove the whole antenna unit off the car
Old May 20, 2008 | 05:03 AM
RoboX's Avatar
never mind i figured it out. if anyone wants to know just pm me
Old May 20, 2008 | 05:12 AM
draxcaliber's Avatar
is it somewhere along the lines of lefty loosey, righty tighty?
and if you already made a thread about this, why don't post up the solution for the next person who searches for this answer?
Old May 20, 2008 | 05:33 AM
RoboX's Avatar
haha yeah good point. yeah pretty much it was lefty loosey, righty tighty. this was the first time ive ever tried to take off the antenna. but it was pretty easy.
1. open rear hatch
2. remove 3 clips from the head liner ( i used a pair of needle nose pliars)
3. pull the corner of the body pannel from both left and right side.
4. slightly pull the headliner down so that you can fit your hands under it.
5. take a look in and youll see under the antenna a singel nut about 19mm with a wire coming out of it
6. loosen and take off that nut.
7. carefully remove a little more of the pass side pannel
8. follow the wire coming from the antenna (itll move towords the pass side). and remove them from the clips that hold it in place.
9. about 3' down there are 2 connectors at the end of the wire. push the clip in and pull the connectors apart.
10. go to the top of the roof and just pull that sucker out
Old May 20, 2008 | 05:41 AM
also, it makes more sense to post it up here instead of answering a PM every other day typing the same thing over and over again.
SoKrispy
Scion tC 2G Aero & Exterior
Oct 13, 2015 03:48 PM
Threequalseven
Aug 26, 2015 04:24 PM
bmxScion
Jul 23, 2015 12:07 AM
Latexbullet
Jul 21, 2015 04:02 PM
excessads
Jul 13, 2015 11:41 AM
