1st time changing oil
I know it's easy to do as changing toilet paper rolls. So I decided to give it a try.
Only problem is....
I don't know what the drain plug looks like and where its located? I was able to locate the oil filter if that helps to tell me?
Please can someone give me quick picture of it? I spent about $70-80 bucks already to get everything hydraulic jack, oil, oil filter, and oil filter wrench. I really don't want to wait for the next oil change since I do have the week off.
Thanks! :D
Only problem is....
Thanks! :D
If that car is warm, don't do the oil change, lol. That oil can get HOT, and without a lift and experience, it's very hard to get the plug off without getting any oil on yourself.
Also, make sure you position the catch pan slighty behind the pan, to anticipate the projectile.
Okay thanks!!!!
Unscrew oil cap. Lay down oil drain pan. Let oil shoot out. Put oil drain plug back in. Take out old oil filter. Fill new oil filter about 3/4s of new oil and lube buttom. Turn the oil filter- right. Put in 4 quarts of new oil.
It's done.
Is this correct?
It's done.
Is this correct?
Right now the car is still jacked up. I have TRD medal cap and was able to touch it without burning my self. I think it's been hour but I did do over hours worth of driving earlier.
yeah, you should be good to do it now. i get it up to operating temp. and let it sit about 30 minutes so it's not crazy hot before i pull the drain plug. i never knew you had to put new oil in the filter though. i always just lube the gasket and stick it on there.
I saw it on DIYarticle earlier....That's how I know. It's 2/3s to fill not 3/4s
Here..
http://autorepair.about.com/od/regul...oil_change.htm
Yeah, the filters can be a _____ to get off, especially when you have your arm twisted up and can't get any leverage..Just keep trying at it, it will eventually break loose, also make sure you're turning it the right way
Also, in the first post, you mentioned the things you bought...I suggest getting some jack stands. If you're only using the jack, it's not advised that you leave the jack as the only support for the vehicle. You can pick up a set of 2 jack stands from Sears (craftsmen) for only $20. I've been using mine for the last 4 months, non-stop (vehicle has been sitting on them) and they're still perfect. Just a safety precaution.
