Is it worth going from trd springs to htechs?
Is it worth going from trd springs to htechs? I want a more aggressive drop and i have trd springs now. I have 18 inch wheels and i dont wanna rub that bad so i dont wanna go to s techs. H techs are a lil more then the trd, so im just wondering if it is worth it?
thanks,
mike
thanks,
mike
Anything is worth it instead of the TRD springs. TRD springs give you a hardly noticable drop. Go for the H techs. And just because you have 18s doesnt mean you will rub on s techs. Im pretty sure there are people on 19s and 20s on S techs that dont have problems. It all depends on your offset
i looke dinto the hotchkis, but i like the way the htechs look. I just dont wanna get something to high again, then have to go and buy another set of springs. Yea my friend just put on s techs and hes already tuckin 17's, and i dont wnna go to low to loose performance.
Originally Posted by BlueJDMBoxV2
s-techs if your going to go with tein. the h-techs are not worth your time they barely drop you.
AFTER
taken the same day they were installed right there in the driveway
this is now running 8 months with my 18s and 40 series tire
HOW IS THAT BARELY DROPPED!!
go with Htechs ull be very happy!!
yea i dont like the fact that the rear is lower then the front with the hotchkis. Thats part of the reason why im gettin out of the trds. chicotuner i think ur pictures made up my mind. That drop is exactly what i want.
If I recall, h techs are a 2" drop? 1.4 is the best for handling, and any lower is actually not going to handle as well. So if you just care about looks, then the h-techs may be ok. If you are trying to make the car handle better you are better off with something under a 1.5 inch drop. The TRDs are actually about 1.3 after settling which is pretty close to the right drop. The spring rates could be higher, but they are a decent mix of street and handling.
I was waiting for you to post, the drop with htechs are 1.9 in the front and 1.5 in the back. Do you think id be able to tell a differance in loss of handling by switching to h techs?
TRD & H-techs have almost identical spring rates, differences are related only to ride height. H-tech drop looks better IMO, which is why I chose them, but you will scrape the front lip more, especially if you mistakenly take steep driveways head on.
If you're planning to autocross better off staying TRD. Too severe a drop throws off your suspension geometry, like engifineer said closer to 1.3-1.4 inch drop is optimal for handling. For example, Sport Compact Car put coilovers on their Project tC car; their suspension gurus determined the best ride height for corner balancing was about a 1.34" drop.
