gettin headers
Old May 21, 2008 | 02:27 AM
stilsick's Avatar
Default gettin headers
i got an 07 and already got injen cai and tsudo catback.
i wanna get headers but should i change the mid pipe and s pipe and pulley also?
and what does it mean when the headers say 4-2-1 and 4-1?
and which headers should i get
thanks!!
Old May 21, 2008 | 02:56 AM
Aroddalobster's Avatar
um.... if you got a catback i see no reason for you to get another midpipe. if you do get aftermarket an header and s-pipe, be prepared to get rasp and lots of it. pulley, i'm not so sure of, since i felt minimal differences when i had it installed. 4-2-1 just means 4 pipes become 2 then 1, and 4-1 means 4 pipes become 1. but iirc, there's only 1 4-2-1 header for the tC
Old May 21, 2008 | 04:31 AM
lee_tC's Avatar
yea u have catback so no need for new midpips the new header not headers...should just bolt on and get 4-2-1 they give more power if u going for performance
Old May 21, 2008 | 05:04 AM
lvlonkey's Avatar
from my experience with my old car, a 4-2-1 header will have better low end power while the 4-1 header does better up top.
Old May 21, 2008 | 06:19 AM
^no.^ 4-2-1 gets less backpressure, meaning that it'll get worse low end, but getting a bit more pull in the top end. 4-1 will only lose a bit of lowend torque, but gain only a bit in the higher revs.
Old May 21, 2008 | 06:44 AM
Trivecta's Avatar
i recall the exact opposite...I thought 4-2-1 had more low end torque.
Also MMW, Tsudo, and Mazzuri make 4-2-1 headers but they're pretty much the same design, tsudo bein the cheapest
Old May 21, 2008 | 06:45 AM
AcidDrop's Avatar
get the s-pipe and the pulley, headers give out rasp and you will have you check engine light on which will set the car in limp more, yes there is a anti-fouler for it but it's a 50/50 chance it'll work. as for the pulley i like mine because i did feel that it helped out abit more. which brand of headers to go with...i'd have to go with DME and my reason is because i have not heard any negative reviews about them and let say you plan on getting the supercharger in the future and these headers will give it enough clearance so it won't rub. i have megan and there ok i'm sure mine leak but eh the heck with it LOL.
Old May 21, 2008 | 09:43 AM
stilsick's Avatar
thanks guys, but still not sure which header to go with?
megan? alphaworks? dc? other? help?
thanks
Old May 21, 2008 | 10:58 AM
jblaze4lif's Avatar
get the tsudo 4-2-1 header + spipe .... 400 bucks, definitely get a new high flow cat and a better resonator to replace the resonator on ure tsudo catback .... search resonator i forget the name of the really good one everyone been raving about ....
Old May 21, 2008 | 11:05 AM
jblaze4lif's Avatar
ah i found it for you bc im that nice
Aero AR25's
http://moesperformance.com/index.php...Path=53_69_311
anyone know a cheaper site ??
Old May 21, 2008 | 01:21 PM
AcidDrop's Avatar
for headers go with either DME, DC, or MMW. alphawerks aren't made anymore and good luck finding them in the classifieds, megan leak and they still have issues which is why they cost less then the rest.
MMW comes with the s-pipe as well but it's pricey=$600
DME & DC are about $300 and with a megan s-pipe you are looking to spend about $500 but that is all up to you.
Old May 21, 2008 | 03:58 PM
lee_tC's Avatar
if u dont wat to get the spipe separate with the header than get the weapon R headers they are 4-2-1 i would had got those but going turbo so no use hahahha
SoKrispy
Scion tC 2G Aero & Exterior
Oct 13, 2015 03:48 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
stayintrucha
Regional - Pacific South
Aug 27, 2015 05:01 PM
