engine idle under 300rpms
Old May 23, 2008 | 07:08 PM
vvti24's Avatar
Default engine idle under 300rpms
I just got an oil change and now my car is idling under 400rpms. One time it died. It vibrates a lot and then gradually goes down to 0rpms where the car is basically dead. There is no check engine light. Could it be the gas that I use, the change from synthetic to regular oil, or a broken sensor? My only power mods are injen intake and trd exhaust. Please help, I don't feel like buying another new MAF sensor.
Old May 23, 2008 | 07:55 PM
Sciontistical_One's Avatar
your MAF sensor may just need a good cleaning
Old May 23, 2008 | 08:42 PM
tcdaily's Avatar
that or your throttle body needs cleaning, maybe new spark plugs.. or it can even be bad gas.. (not in a immature way.. haha)
Old May 23, 2008 | 11:52 PM
vvti24's Avatar
true.. im going to look into the spark plugs and thorttle body.. i cleaned the MAF and reset the ECU.. my car didnt die and it the idling went to normal.. but it still vibrates and occcasionally goes down to 300rpms..
Old May 24, 2008 | 02:08 AM
tcdaily's Avatar
yeah it may be the spark plugs, that'll cause idleing issues
Old May 24, 2008 | 03:55 AM
engifineer's Avatar
Or of some reason they disconnected the battery, which means it will idle rough for a bit until you drive it a while and it relearns.
Unless something else is wrong, you plugs should be fine if you are not pushing 100,000 miles or so.
Old May 24, 2008 | 04:01 AM
darkflare999's Avatar
Hey What about a Vacuum leak?? That can cause a idle issue
Old May 24, 2008 | 04:11 AM
draxcaliber's Avatar
maybe need to put some fuel injector cleaner through it to unclog some injectors.
Old May 25, 2008 | 12:54 AM
vvti24's Avatar
thanks for the quick replies guys.. great resources..
dbg326
May 31, 2015 05:29 PM
D_Roke
Mar 31, 2015 05:37 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
cid_mcdp
Jan 5, 2015 02:45 PM
sensez
9
Dec 29, 2003 06:26 PM
