SHORT SHIFTER PROBLEM...
Old May 24, 2008 | 12:26 AM
cluelessTC's Avatar
Default SHORT SHIFTER PROBLEM...
I just got a doc short shifter....and after i installed it the gear to gear shift is very tough. i put marine grease on it and everything. anyone know what is wrong?
Old May 24, 2008 | 01:45 AM
Foe's Avatar
Foe
Should be a cleaner crisper shift...... not tougher as to a point of discomfort. Did your S.S come with craddle/cable bushings? and if so, did you replace the stock ones with them? it will feel a little tougher seeing that you removed all the exess play, but it shouldnt be a discomfort to shift. Check and make sure everything is where it should be. Leave the surround off of it and shift back and forth to see if somethings up.
Old May 24, 2008 | 02:40 AM
cluelessTC's Avatar
I put the cage bushings on but not the cable bushings. what will the cable bushings do?
Old May 24, 2008 | 02:56 AM
Foe's Avatar
Foe
Cable bushings are actually the better mod of the two. Install them when you get a chance......you'll like the shifts alot more. If it doesnt get any better try contacting drisotope with some questions, but it'll be better.
Old May 24, 2008 | 03:01 AM
Foe's Avatar
Foe
Ohhh sorry. to answer your question theyll further tighten and smooth your shifts. The cage bushings only tighten the craddle so your shift throw is sturdy.
Old May 24, 2008 | 03:08 AM
cluelessTC's Avatar
thanks for your help
Old May 24, 2008 | 03:11 AM
Foe's Avatar
Foe
No problem bro.............its what this site is intended for.
Old May 24, 2008 | 03:37 AM
Ace83's Avatar
Ronin Scion
yeah cable bushing is so much an improvement.. i say do it, but yeah shifting will take a lil more effort but its much crisper and feels better.. but you will get used to it, i dont even notice it anymore.. i tried driving an evo mr with stock shifter and i said to my self dang this shifter sucks haha mine is better
Old May 25, 2008 | 05:39 PM
cluelessTC's Avatar
should i reuse the washer that is on the cable bushings?
Old May 25, 2008 | 06:39 PM
BoostedBeastBox's Avatar
I have cable and base bushings and it took a while to get used to it. I like it better now, but 3rd gear still bothers me for some reason.
Old May 25, 2008 | 07:03 PM
Foe's Avatar
Foe
only if nesessary. I went with TWM so they might be a little different from mine. But if it looks like its needed, it couldnt hurt. Just shift from gear to gear to make sure everythings working well before you put the intake back on.
Old May 25, 2008 | 07:12 PM
Foe's Avatar
Foe
x Batman x has a write-up on here.....check it out when u get a sec if u havent allready.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
