Dome light and Headlight On Sound?
Old Dec 3, 2004 | 05:46 PM
djaaronp's Avatar
Default Dome light and Headlight On Sound?
Ok guys, got a question maybe a few of you could answer for me.
When I come to a stop. turn the car off, take the key out, open the drivers side door, the dome light does NOT come on. But, if I open the passenger door, it does. (yes the switch is set to door). Isnt the dome light supposed to come on when the drivers door opens too?
Also, if I leave my headlights on, take the key out, open the door, there is NO buzzer, bell, whistle, anything to let me know I left them on. Isnt there supposed to be something, I thought I read in the manual that it was. I left them on at work and probably drained a lot of the batter. Stupid, I know.
Anyone else seen/have this issue?
Old Dec 3, 2004 | 05:49 PM
Silly_tC's Avatar
well i kno that if you leave your lights on and u get out of ur car after u take the keys out, they will turn off automatically but im not sure about the dome light tho
Old Dec 3, 2004 | 06:03 PM
djaaronp's Avatar
The lights didnt turn off automatically. I might have had just the running lights (first step on the switch) though. I dont remember.
I do remember that they were on when I came out from work, luckily the car started right up.
Old Dec 3, 2004 | 06:04 PM
ScummyMcOwnage's Avatar
my headlights wont turn off either after i take out the key, and lock the doors.
Old Dec 3, 2004 | 06:06 PM
PMok's Avatar
check the sensor on the driver side door jamb to see if it might be stuck - I know I have this problem sometimes on my '92 MR2 where the sensor still thinks the door is closed so no dome light, no buzzer etc. But that is weird if it is happening on a relatively new car.
Old Dec 3, 2004 | 06:07 PM
3_IGs's Avatar
Yes - the dome light should come on when driver door opens.
No - there is no buzzer for your headlights...they turn off automatically if they are left on when you take the keys out and shut the driver door.
Old Dec 3, 2004 | 06:08 PM
djaaronp's Avatar
Where on the door is this sensor? Is it on the back edge where the door lock mechanism is, or the front side where the door hinge is?
djaaronp's Avatar
Really, this is cool. So if I close and lock the door they should turn off, after how long?
Old Dec 3, 2004 | 06:13 PM
PMok's Avatar
on the back edge near the door lock. I don't have my tC yet so I don't know what it looks like on the tC, but just look for something that moves like a switch, you can leave the key in and play around until you see the dome light go on and off or the buzzer comes on.
Old Dec 3, 2004 | 06:16 PM
3_IGs's Avatar
If I leave my lights on - remove the key - shut the driver door - they go off as soon as the door is shut.
However, IIRC, if you turn your lights off and turn the car off and then turn the lights on for some reason (w/ the key @ the accessory position) the lights will remain on when you remove the key and open/shut the driver door. Did that confuse anyone?...because I came pretty close to confusing myself. :D
Old Dec 3, 2004 | 06:24 PM
basilisk4's Avatar
Exclusive
If you open the door before the key is turned to the "off" position, I don't believe the headlights turn off automatically.
Old Dec 4, 2004 | 01:34 PM
3_IGs's Avatar
....correction - the lights go off as soon as I open the door (as long as the key is out of the ignition).
Old Dec 4, 2004 | 10:38 PM
cello8619's Avatar
This is a Toyota, feature the Lilghts should turn off when you open the door and the key isn't in the Ignition, my 96 camry has the same feature. It sounds like the open door sensor on the door jam is bad, to test and see if the sensor bad open the drivers door, and see if the light on the dash is on. I would bring your tC back to the dealership since its on warenty.
horsefeathers
Sep 17, 2023 11:12 PM
Cadillac15
Jan 29, 2015 07:34 AM
scsteven
Jan 25, 2015 01:06 AM
corbmonster
Jan 24, 2015 05:22 PM
LeChuck
Dec 9, 2014 02:26 AM
