View Poll Results: Emanage or SAFC2?
Greddy Emanage
62.50%
Apexi SAFC2
37.50%
Voters: 8. You may not vote on this poll
Preperation for boost, semi-technical question...
Old Dec 4, 2004 | 04:18 AM
Tcguy's Avatar
Default Preperation for boost, semi-technical question...
I've been talking to my sponsor a lot lately and we're finally starting to prep the tC for some boost in March. I haven't had any time to take the plastic sheild by the windsheild off yet to look at some things, but I'm wondering...
1. Does our fuel system consist of a return line, or is it returnless?
2. What size injectors does our car use stock?
3. Are our stock injectors a standard lengt or shorter than normal? -I ask this because my turbo civic had short injectors and the only way to upgrade was to make a custom spacer for the fuel rail.
I think that covers what I've been curious about. My sponsor said he already ordered me the H&R suspension so hopfully that helps keep the power a little more under control. He told me I have a chance in a free front and rear full big-brake kit from a large name brake company (can't say yet). He's in a tossup right now on if I should go with the SAFC2 or not. I think I'm going to buy it, but not sure if I should be running an emanage. An emage has sub injector control, and injector correction features. The SAFC2 looks nicer, is self contained, and has a screen. The Emanage, though it has more power, needs either the Profec-e01 or a laptop with the support tool. I already have the support tool, software and laptop from my turbo Civic, but I like the idea of the SAFC2.
Any input guys? I plan on posting up everything I do, as I go, to help you all out for those who plan on boosting as well.
Old Dec 4, 2004 | 02:32 PM
Tcguy's Avatar
wow no input from anyone?
Old Dec 4, 2004 | 03:25 PM
Littleguy's Avatar
I wouldn't go with the safc2 if I were you. When your going to be boosting a car that is meant to be n/a your main concern as far as safety for the engine will be fuel. The safc2 doesn't have nearly the capability of the E-manage. I think although the E-manage (with boost, ignition, and injector harness) and the profec eo1 combo will be more expensive you will also see better and safer results imho.
Old Dec 4, 2004 | 06:29 PM
panasoanic's Avatar
All I know is that the tC has a returnless fuel line. I am sorry that I can't help you more. Please keep us posted though.
Old Dec 4, 2004 | 10:21 PM
Littleguy's Avatar
Also, I know an safc and safc2 won't work with our celica's because of the way our stock ecu's function, I'd check and make sure that the same thing is not true for he tC as well.
Old Dec 5, 2004 | 12:20 AM
silverstarsciontc's Avatar
You'll want an emanange. You'll want to be able to clamp the stock mas signal and then add fuel using the injector drivers on the emanage.
Old Dec 5, 2004 | 04:36 AM
Tcguy's Avatar
Damn that sucks. Guess it's the RSM for now for monitoring purposes. I'll call my sponsor this week and try to find out the settings for an emanage. He said he can get me the ECU and wiring diagrams too, so hopefully that helps.
Old Mar 17, 2007 | 08:02 PM
pasciontc's Avatar
Signature Visions
i want boost
crimson_sinn
Sep 25, 2015 09:41 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
brett561tc
Sep 15, 2015 06:33 AM
