jct
06-06-2008, 10:59 AM
crazy idea... would it work if i put one in front of the a/c condenser (like a flex-a-lite) to help give me a colder output in my car for my already weak a/c system???
View Full Version : electric fan + a/c = ??? jct 06-06-2008, 10:59 AM crazy idea... would it work if i put one in front of the a/c condenser (like a flex-a-lite) to help give me a colder output in my car for my already weak a/c system??? DarkSide_xB 06-06-2008, 01:31 PM that would be like taking a page out of the Honda Book. i dont see why you couldnt alot of there cars have an axtra fan behind the condensor pulling air thru. so go for it, let us know how it works out for you. Reactor 06-06-2008, 06:05 PM I want to to that especially since i have a nice low profile SPAL that would fit between the bumper and condenser. The only thing i have not decided is how to activate it - its only needed with AC on when not moving, Any ideas other than a crude switch on the dash? jct 06-06-2008, 09:23 PM i had a few ideas on how to hook it up with the a/c switch/button or maybe a 3 way switch (off, low, and high) i'm just trying to get ideas Metro273 06-06-2008, 10:41 PM The extra fan would also block some much needed air to the radiator to cool down the hot coolant too. Reactor 06-06-2008, 11:02 PM The extra fan would also block some much needed air to the radiator to cool down the hot coolant too. By a neglegable amount, i think. jct 06-07-2008, 12:46 AM i'm just glad i'm still at the idea stage of things so it can get knocked down and i don't have to spend any money :D haha Cinderblock 06-07-2008, 06:18 AM look up the wiring diagram, find out where the power wire for the ac condensors clutch is, and tap into it, so when you turn the a/c on, itll kick on the fan, then you can have a manual over ride switch on the ground side of the wire, so if need be you can turn the fan off, bam your done lol. and a fan wont block much air. try having your a/c system recharged too. what year is the car? Reactor 06-07-2008, 07:23 AM I think if the fan shows through the lower grille opening,- it'd look niiiice. I might throw gauges on the AC lines to see if it even makes any sense to have the add-on fan ON before the factory one kicks in. Bacause the one thats allready in the car is operated by the high-side line pressure switch. jct 06-07-2008, 03:51 PM its an '05 Cinderblock 06-08-2008, 03:08 AM really? my fan kicks on when the my oil temp hits 180, dont have water temp. is their more than one fan, cuz ive only seen one, and it runs off engine temp, not a/c line temp. and better evaporator is waht would make a cooler a/c anyway, not a cooler condensor, itll help but not as much. the evap is what actually cools the air down, if you want your a/c to work better for the moment, dont put the blower fan on high, the faster the air passes through the evaporator, the less it gets cooled down ya know. jct 06-08-2008, 03:19 AM haha yeah i noticed that as well about the fan speed setting Reactor 06-08-2008, 05:07 AM really? my fan kicks on when the my oil temp hits 180, dont have water temp. is their more than one fan, cuz ive only seen one, and it runs off engine temp, not a/c line temp. and better evaporator is waht would make a cooler a/c anyway, not a cooler condensor, itll help but not as much. the evap is what actually cools the air down, if you want your a/c to work better for the moment, dont put the blower fan on high, the faster the air passes through the evaporator, the less it gets cooled down ya know. Here is what i know : xB uses 1 fan but 2 control circuits. ECM can activate both fan relays based on either the coolant temp sensor reading (FAN1 relay circuit), or the AC high side line pressure switch (FAN2 relay is activated and the radiator fan turns at lower speed because there is a resistor in that circuit). So even if the coolant temp is low, but the pressure in the AC high side gets high, the fan should come on. Here is what i think i know: Late in production Toyota addressed the poor AC performance by increasing the size of the condenser. Look at yours. If its the same size as radiator, then you have the latest version. If the condenser on your car is about the half the size of the radiator, then its the earlier version. I admit, i am not 100% sure about that though. As someone who worked with AC systems for years, i must say that the size of the condenser makes a difference, especially in hot climates like SoCal. When back in the 90's we first started retrofitting old R-12 systems to run on R-134 refrigerant, we would always try to add extra fan in front of the condenser if possible, because R-134 does not cool as good as R-12 and one of the ways to compensate for it was to cool the condenser as much as possible. Cinderblock 06-08-2008, 06:29 PM ill have to look at my condensor, im not sying changing the condensor size doesnt help, i just thought the evap did more? if not now i know, i know how R12 cools better than 134. didnt know about the second fan relay, becuase i llike never use my a/c lol. it works ok but i dont like how sluggsih the car is with it on lol. thanks man i now know something new Black_Sheep_xB 06-09-2008, 01:47 PM The fan comes on with the compressor.. the safety switches shut down the compressor if pressure is too high/low Once you hit that A/C buton the fan comes on via a relay.. Stays on with the compressor as it cycles.. if the compressor cycles off, but the temp rises then that system comands the fan A second fan would work, because as long as you use the same signal, the power to the OEM fan, the fan would come on for a/c and over heat command (so if it did block some airflow, it would then make up for it, and in theory cool everything quicker) .. helping both.. the factory doesnt see the need for a second fan, but they also didnt see the need to change the a/c system any for the xB vs the xA.. Also, electrical pull is something to consider.. a fan on high draws less amps.. and I don't see the need for a low/med/high switch any way.. just high If you use a relay to power the aux. fan directly from a added power source (batt. or add a fuse circuit), and use the power wire to the OEM fan to signal the relay.. everything should work out We built a 75 stingray up for a guy, and he wanted an ice cold a/c.. we ended up adding 2 fans and everythinbg worked great cobb 06-15-2008, 03:16 AM The benz I had had horrible ac performance. I would rig the electric fan that only came on when it reach 230 degrees to stay on with the switch by using a paper clip in the high temp switch. It made a world of diference. My condensor is the same width as the front of the car from head light to head light and the radiator is rather small. I too want to do the fan mod, but am rather stuck on how to work it short of just using the acc fuse as a trigger so its on with the key, then disconnect it in a few months when it cools out. I would stick the fan on the passenger side on the condensor only and on the front side right behind the grill. Reactor 06-20-2008, 08:44 PM Here is a test i did today: 06.5 xB parked in the shop. Outside temp 95F. At idle the temp out of the center vents, recirculation ON, AC Max - 48-50F With the industrial 2ft diameter fan directly in front of the car - 45-48F Raising the PRM didn't do any difference other than making AC cycle with higher frequency. So the improvement is very slight- adding more airflow does not make the AC run cooler than by may be 3F. As i said before, my 06.5 came with the bigger condensor than the earlier models- its the full width of the radiator grill opening. cobb 06-21-2008, 03:03 AM 3 degrees? SOLD!!!!!! I just find it strange that of many cars, trucks, suvs, vans, etc, this little car just has a fan for the engine radiator, not a secondary fan on the remainder of the condensor. Thats my next mod. jct 06-22-2008, 10:34 PM i have a full size condenser on my 2000+5 just remember there is the fan shroud so that helps way bunch too... cobb 06-24-2008, 03:26 AM I puttered around in stop and go traffic in 80 degree weather with outside air ac on bluest setting and fan speed 3. When I finally got to 40 mph I felt the air start to feel colder. Also earlier today went out for lunch. No sooner I started the car within 3 second I got cold air. Then teh fan outside on the radiator reved up into high gear. The ac was cool, but not really cold. For the most part the fan stayed on til after I left the fast food place drive up and again one I got to rolling it startd to cool down. Going to go for the fan next month when I get this over time done. Going for the 10-12 inch one as it takes least amps and can power using my old aftermarket fog light harness kit and just turn it off and on as needed and hook the trigger wire to the acc fuse so it cuts on/off with the key. cobb 07-09-2008, 02:21 AM I did it. See photo in profile. Works up to 40mph in making the air cooler. I got temps from 41-43 degrees with the fan on. Its hooked to a fog light harness relay kit I currently am not using. Reactor 07-09-2008, 06:29 AM Congrats on a original mod! So is it worth it? Did you wire it through resistor or straight to 12v? I saw the pics, looks tight. cobb 07-09-2008, 01:45 PM Original? Ha, ha, thanks for the idea, althought Ive had the idea for a few months. No resistor or anything, straight connection to a generic advance auto fog light harness. To tell you the truth, even with it off, it makes the ac feel cooler. I wonder if if has a funnel effect on moving the air through the grill vs letting it gather up or go else where? It makes a big differene at idle, plus you dont hear the fan kick in to high gear. Reactor 07-09-2008, 03:52 PM I am sure many people have been thinking about it, but you are the first one who i know of actually making it work. I'll probably try to do this on my xB too. Was thinking about installing the closed throttle switch to have the fan activated at idle only. BTW, is the fan being ON affecting the idle speed at all? cobb 07-10-2008, 02:32 AM Well, the 240d benz I use to own had an electric and mechanical fan. To my knowledge the electric one never turned on unless the car get up to 230 degrees as it was a diesel. I stuck a paper clip in the hot sensor so the fan stayed on with the key. I noticed the ac worked way better once the car got rolling and assumed air flow was the key as it can get very hot under the hood with the ac on. I assumed the same worked here. Man, it does. Having ms, the heat sucks the energy out of me and sometimes after I walk to my car I sit a few seconds with the ac on and roll around the parking lot before I head off to freshen up. Now its from turn key its cold. Sometimes it takes a few blocks or miles for the ac to cool down, not anymore. Well worth the 50+ bucks for the fan. Think the fog harness was 15 bucks. For short trips, I just leave the fan on when I run in a store. It doesnt effect the idle, but in the past I know when I idiled with the ac on the idle would creep up to a grand. I drive at low speeds 25 mph where I work and live. I work and live near a secure environment and those are two places I notice the ac wimps out. Like I said, after 40mph the fan makes no difference, but since electric motors require more to spin up than run, I just leave it on from start of trip to end. Reactor 07-10-2008, 05:51 AM Well, great! I hope people who want to improve their A/C's will consider this mod. Winter 07-10-2008, 07:46 AM just an FYI, using that secondary fan for the condenser doesn't block as much of the radiator as most would think. our radiators are RIDICULOUSLY small... and where you've got your fan going is just barely covering the left side a bit and nowhere nearly enough to have any effect either. our radiator is only about 18 inches wide and starts from the driver side parallel to the driver side headlight and goes in 18 inches from there. after that it's just a huge plastic wall with a couple rubber flaps on some vents that don't do much for added cooling to begin with other then to push out hot air in the engine bay a little. Reactor 07-10-2008, 03:45 PM I agree. Fans dont block the air flow when they are off. cobb 07-11-2008, 11:58 PM The radiator is a bit bigger that what I have seen on other rice burners like the scion. True the fan I installed only blocks a 3rd, but I didnt want to cause any problems at one end of performance vs the other as some mods can do. Would I put in a hugh fan to cover the whole area or two smaller ones. Yeah, I would if moeny was no object and the time to do it, but I just wanted to help the ac at slow speeds and it works. Infact the engine will idle down if the fan is turned on while at idle with the ac on max from the 3/4 to 1 grand to 1/2. Anyone notice at idle with ac on the engine idles up? |
