ichiba wheel spacers...how much longer are the studs?
Old Jun 11, 2008 | 04:35 AM
DonNguyen's Avatar
Default ichiba wheel spacers...how much longer are the studs?
i was wondering how much longer the studs are on the ichiba wheel spacers...
with the 5mm spacers are the studs 5mm longer?
Old Jun 11, 2008 | 12:19 PM
davedavetC's Avatar
yup
Old Jun 11, 2008 | 02:24 PM
DonNguyen's Avatar
so 15mm longer with the 15mm spacers, 20mm longer with the 20mm spacers and so on and so forth?
Old Jun 11, 2008 | 04:23 PM
davedavetC's Avatar
i think so, i think with 25mm and up they have the studs built in.
Old Jun 11, 2008 | 04:31 PM
DonNguyen's Avatar
cool...thanks dave...
i was just curious if they all had the same length extended stud or what and if i'd have to run open ended lug nuts or not
Old Jun 12, 2008 | 12:04 AM
davedavetC's Avatar
i guess if you got 20mm exteded lugs you could run any spacer under that with open ended lugs, but id just get the right size and go with those red rays
Old Jun 12, 2008 | 01:00 AM
DonNguyen's Avatar
check the other thread....red rays were out until an undetermined time
Old Jun 12, 2008 | 01:23 AM
DonNguyen's Avatar
ok...i found out that for the 5mm spacers, the studs are 35mm long, which i believe is stock length
for 10mm and 15mm spacers, the studs are 45mm
Old Jun 12, 2008 | 01:59 AM
davedavetC's Avatar
i know that the studs i have for my ichiba spacers are 15mm longer (i have 15mm spacers.)
Old Jun 12, 2008 | 02:36 AM
DonNguyen's Avatar
interesting
Old Jun 12, 2008 | 02:39 AM
davedavetC's Avatar
yea... they fit like stock once the spacer is installed. i have rays extended lugs ...
Old Jun 12, 2008 | 02:55 AM
1_kLEan_tC's Avatar
if you a get a 5mm spacer...you don't need extend lugs..I'm running them w/o extend lugs.
Old Jun 12, 2008 | 02:58 AM
davedavetC's Avatar
i wouldnt do that for long man... the spacers take away 5mm of your studs and that means your lugs have 5mm less to grab on to. they make them certain lengths for a reason man. i would throw those ex studs in there to play it safe.
Old Jun 12, 2008 | 03:07 AM
1_kLEan_tC's Avatar
5mm is not that much...the rule of thumb is that if you can get 6 turns on your studs...you are fine this is from van at one ton garage and others....
Old Jun 12, 2008 | 03:08 AM
davedavetC's Avatar
eh i still wouldnt put that against toyotas engineering. they made the studs that length for a reason.
Old Jun 12, 2008 | 03:25 AM
1_kLEan_tC's Avatar
Trust me its ok....I have done my research ...I have gotten crazy on my suspension with the spacers on your going to be fine...
Old Jun 12, 2008 | 05:31 AM
DonNguyen's Avatar
i believe toyota stud length is 35mm so it wouldnt matter with the 5mm spacers anyways
Old Jun 12, 2008 | 11:48 AM
davedavetC's Avatar
i would just play it safe, just my opinion tho. i dont like messing with stuff like that.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
Deves
Feb 8, 2015 11:37 PM
BManAmericae
Jan 18, 2015 12:17 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Docofmind
Nov 11, 2003 07:09 PM
