View Full Version : Engine Swap...
smurf3642
12-06-2004, 02:18 AM
What engines out there would fit in the tC's engine bay??
Supra?? -more concerned with right now...
ScummyMcOwnage
12-06-2004, 03:21 AM
unless you plan on making the tC RWD, you're not getting a supra engine in there....there is a topic on this, I'll search for it.
BSP_5c10n
12-06-2004, 03:24 AM
Wow the car JUST came out and already we're talking engine swaps. :roll:
JSVH
12-06-2004, 03:28 AM
I think the V6 from the Camry would be your best bet. Forced induction is probably a better option though.
ScummyMcOwnage
12-06-2004, 03:36 AM
http://www.scionlife.com/forums/viewtopic.php?t=35700&highlight=engine+swap
lriicelboy
12-06-2004, 03:56 AM
i wouldn't mind a RWD tC.... =) drift!
spider
12-06-2004, 04:25 AM
thats what i'm sayin'. why would you want to swap the motor out? the current motor has plenty of potential. a lot of aftermarket parts, as well as forced induction kits are coming out (greddy and turbonetics are working on turbo kits).
ScummyMcOwnage
12-06-2004, 04:28 AM
i wouldn't mind a RWD tC.... =) drift! If they don't make this, I plan on keeping my car and fabricating a RWD tC as a project waayyy down the road, just for the hell of it.
hahaitzskippy
12-06-2004, 10:12 AM
good idea, the V6 engine is HIGHLY TQ'y and is REALL fast if you put SC on it. but question is, willl it fit??? i dunt think so,
smurf3642
12-06-2004, 04:41 PM
that's the MAIN question I am asking...
is there room to add bigger engines??
spider
12-06-2004, 06:02 PM
anything is possible with enough money.
JSVH
12-06-2004, 08:02 PM
There is enough room in the engine bay if you are willing to work with it. It’s just a matter of figuring out what will fit and how much fabrication is involved. I would not be that surprised if you could drop the Camry V6 right in with little effort. Since we have the 4cyl Camry engine the mounts are probably the same. Of course with any engine swap you’re in for a big project. You have to worry about bunches of related components being compatible: Transmission, ECU, exhaust, fuel system...
Serialk1llr
02-10-2006, 09:13 PM
**Resurrects a dead thread**
For the sake of kicking around weird ideas, what about a celica 3S-GTE swap, or a 1MZ-FE v6 (Out of the Lexus/Solara, and others)? Been reading a lot on the MR2 forums recently. Yeah, I know the 3S-GTE is a smaller engine, but is it more sturdy? I know so little squat about the camery v6.
I figure, hey, if they can jam a v6 in a MR2, why not us?
ScionBandit
02-10-2006, 09:24 PM
ur on the same page i am
TheQuietThings
02-10-2006, 09:29 PM
have you ever actually looked at the engine bay in the tC? its tiny to begin with.
Also, if we are going to drop a bigger engine in the FRONT, the weight of the car is going to be distrubuted even worse than it already is.
BTW, moving to NA
HKSpeed
02-10-2006, 11:27 PM
Toyota had to redesign the intake manifold from the Camry's 2azfe because of limited clearance between the engine and the firewall. So I suppose a 3sgte swap would run into clearance issues with the tC's firewall as well (unless you fabricate a custom intake manifold). I dont think you could fit the V6 into the tC, but people have put Camry V6's in 2nd gen MR2's.
3SGTE. yum....
http://www.4agtoys.com/FX16/3SGTE2/3S2.jpg
LBTc06
02-10-2006, 11:42 PM
I've been tossing the idea of putting a 1MZ-FE or even the 2MZ-FE into the tC. I know of a shop that'll do it. And with enough money, anything is possible. ;)
hPower
02-10-2006, 11:50 PM
The 3SGTE would be pretty nice! And a supercharged 1MZ would be pretty cool as well. But at this point, its all speculation. I dont think anyone really knows for sure simply because no one has tried a swap yet... at least as far as I have seen or heard.
Serialk1llr
02-11-2006, 01:35 AM
I'll be the first to say I know squat about the 'possabilities', i just figured if they were cramming in a v6 into a mr2, anything was possible?
I think I was reading that they were running 18-20 lbs of boost on the 3SGTE, and i'll just assume a built block of course. As far as manafold clerance with the firewall, and again keep in ming i don't know a lot, is that a part of the design that could be relocated elsewhere (even if we have a tiny engine bay)
IF it turns out our 2az-fe's are just not up to snuff down the road to really take a beating, i'm under the impression other toyota engines -may- be up for it. So, someone go get us another engine and see if it has problems mounting. Hey, wait, i'll voulenteer my ride for that! *insert sponsorship here* :lol:
TcPrincess
02-11-2006, 02:02 AM
well unless you want to do a lot of work to do a 2J rwd i'd say forget it. a 3S would be cool but you'll probably have a lot of custon work (mounts, axles,...). if it were me i'd just turbo the stock motor. a rwd tc would be cool but thats A LOT of work.
bbsciontc
02-11-2006, 02:18 AM
Ths camry v6 may be a possibility, but the pricing along with the ecu, trans and custom axle's would be so much that you'd be better off getting a turbo, built internals and either a standalone or good piggyback. That would get you more power than the motor swap alone possibly could.
killerxromances
02-11-2006, 02:29 AM
Being that this is n/a tC thread, i'm assuming you want to swap and build up a n/a motor. If thats the case, a 2zz would definitely fit if you like lift motors. If you didn't mind not going with a Toyota motor, your options are fairly endless.
The v6 (camry) will not fit in the tC without a good amount of work, its possible but it wouldn't be worth the money you dish out to make it happen.
Serialk1llr
02-11-2006, 02:38 AM
This is kinda a random idea thread for swap ideas. not so sure its strictly NA or FI.
As far as swapping non-Toyota motors, I would imagin that is a whole new can or worms not worth dealing with? I mean, doesn't that just get kinda crazy? But then again, why not? I was just thinking of using another toyota engine in hopes that motor mounts etc would be closer than another setup from a different automaker. Certainly, i'd think this would be years down the line for most of us, but I like exploring the possabilities.
as far as the camery v6's are concerned, are they any more bullet-proof than our 2az-fe? or, is it the case with any engine, when you upgrade the internals it does not really matter what you started with. maybe its an issue of potential i guess.
WeDriveScions
02-11-2006, 02:44 AM
Guys, this thread has been talked to death many times.... Anything is possible, given the needed cash, but nothing plug and play for sure....
Please see the other threads regarding this, they all come to the same conclusion...
