8 ) Grab you C-clamp and slowly turn the Brake piston back in. (1 turn every 10-15 secs. You want the piston to sit back flush. Afterwards you can now remove the C-clamp
theres already a good DIY on here w/o pics, this one is for the visual learners :wink:
SquallLHeart
06-13-2008, 05:11 AM
Note: You might notice a bit of brake fluid oozing out on top in your engine bay. Nothing to worry about just get a rag and wipe it off.
Actually my dear buddy, brake fluid is probably the most detrimental fluid that's part of your car that can destroy paint.
Also, when compressing the piston.. GO SLOWLY! not only will it prevent your fluid reservoir from overflowing, but also can help preventing issues with your ABS if you really go fast.
datdude1119
06-13-2008, 05:13 AM
THANK YOU!
O5_TRD_tC
06-13-2008, 05:17 AM
I said u might
SquallLHeart
06-13-2008, 05:22 AM
and i said, to "prevent"
should i add "... from ever happening"?
O5_TRD_tC
06-13-2008, 05:29 AM
ok buddy!
AcidDrop
06-13-2008, 05:38 AM
finally i found a DIY and now i know that all i need is a clamp, well here goes my weekend project. :P hopefully all goes well. :pray:
O5_TRD_tC
06-13-2008, 05:49 AM
Buy one at home depot and return it afterwards. Customers do it all the time. haha
jurassic1
06-13-2008, 05:58 AM
Thanks!! :bow:
AcidDrop
06-13-2008, 06:17 AM
Buy one at home depot and return it afterwards. Customers do it all the time. haha :rofl: yeah it's true about returning it. :P
gicode0823
06-13-2008, 06:55 AM
man one of my brake make noise ...
i dont know if its my brake pads or somethin else wrong ...
good write up
AcidDrop
06-13-2008, 01:53 PM
good write upmine used to do that until a friend took them out and put some of that break noise lube and it took the noise away for about 2-3 weeks and then it returned. but now i got some Axxis deluxe pads that have i hope they remove the squeeking noise for good. :pray:
gicode0823
06-13-2008, 03:22 PM
i went to firestone and they told me to change my one of the brake disk but still makin noise ...
well, they said that maybe because of painted caliper ... ?
AcidDrop
06-13-2008, 04:05 PM
i went to some other place and they told me to resurface the rotors and when my friend put some of that brake squeek lubricant the noise went away for a while.
O5_TRD_tC
06-13-2008, 07:14 PM
painted calipers are not the cause haha :rofl:
jurassic1
06-13-2008, 07:46 PM
One thing you can also do is use an old turkey baster (those big droppers) to take out some (not too much tho) of the brake fluid in the reservoir to avoid spilling out when you compress the piston/s.
As you know, everytime we take our cars to service, they usually check & top off the fluids such as the brake fluid. It's routine maintenance. As time goes on, more and more fluid gets added up, so there is a risk of overspill esp. if you change the pads (i.e. compress the brake pistons) on all four wheels at the same time.
Chrisb319
06-13-2008, 09:53 PM
good write up!!!
SquallLHeart
06-14-2008, 10:59 AM
I have yet to really see any service person top off the brake fluid reservoir. I have friends that do service and have seen other service people do routine maintenance.
that little tank doesn't get touched unless absolutely necessary and brake work is actually needed.
you shouldn't need to add any fluid at all. if the reservoir is low.. the VERY FIRST THING that anyone competent should do is to check the brake pads. if they are really, truly, indeed ok and recently replaced (still looking new).. then perhaps you should add a little brake fluid.
(which the only thing i can possibly think of to cause such a thing, is from someone servicing the brake system improperly and they caused brake fluid to be lost in the first place)
davedavetC
06-14-2008, 11:22 AM
another good way to get the piston to get down is to put the inside brake pad back in the caliper and use the c-clamp or a big set of vice grips (locking plyers) to hold down to push the piston back in, make sure you do it slowly tho, like mentioned before.
SquallLHeart
06-14-2008, 11:32 AM
yea.. i usually use some big vice grips. :P
davedavetC
06-14-2008, 11:36 AM
iNck
06-15-2008, 06:36 PM
very nice DIY.
thx!!!
SouLTakeR
06-15-2008, 08:04 PM
Dont push the piston back in by directly contacing it with the C Clamp like that, instead take one of the old brake pads and put it in front of the piston and compress it back like that.
Dakine
06-15-2008, 11:18 PM
Nice write up! nice xsi as well!haha
O5_TRD_tC
06-16-2008, 12:00 AM
Thanks Buddy! :wink:
Rawkerstatus
06-18-2008, 07:15 PM
hey so really... you should actually loosen the bleeder valve from behind when pushing the piston back in. i heard you could damage ur ABS pump if you do it the other way... personally i just do wht every1 else does,
Rawkerstatus
Yanki01
07-03-2008, 03:26 AM
nice, ill need this soon!
malloynx
07-04-2008, 12:56 AM
if your getting noise it's from lack of brake paste or using old clips/backing plate. that autozone brake paste is crap..
also, you ahould perform a brake fluid service every 2yrs. brake fluid is extremly hydroscopic.
another thing,, we have floating calipers, lube the guide pins.
another thing, don't not open the bleeder to do a pad/rotor service, usless you have a PRESSURIZED bleeder hooked up or plan on doing a brake fluid service. you will get air in the lines,,, (remember we are surrounded by 14:7psi of air pressure) the abs pump will by fine.
this is coming from a certfied tech ;)
O5_TRD_tC
07-04-2008, 12:59 AM
^ good info there thanks
a_german_named_hans
07-16-2008, 04:12 PM
question. I only have a 3 inch c clamp. Is that good enough or should i get a 6 inch c clam?
question. I only have a 3 inch c clamp. Is that good enough or should i get a 6 inch c clam?i was in that situation and just bought the 6 inch to be on the safe side, plus it's handy for other projects. :P
zer0myst
07-16-2008, 06:21 PM
good write-up, my neighbor walked me through it last time - feel confident enough to do it myself next time - it's pretty simple.
a_german_named_hans
07-16-2008, 09:32 PM
I'm about to order some brake pads of sparks. The grease I could pick up at any auto shop right? Is it called anything in particular or does anyone recommend a specific grease?
DonNguyen
07-16-2008, 09:38 PM
its called stop squeak or something...
Ace83
07-16-2008, 09:46 PM
hey i thought this was in tech section?
Hunner
07-18-2008, 04:39 PM
Nice DIY! I'll be using this soon. Thanks. :clap:
MountScion1
08-29-2008, 09:31 PM
I just did my front brakes thanks to this thread. Big Thanks!
drjohnson36
08-31-2008, 05:01 PM
Are doing the back brakes similar to the fronts? This should be sticky-ed too by the way.
MountScion1
08-31-2008, 06:16 PM
there is another DIY with pics specifically for the back brakes
GammaTNT
10-23-2008, 06:09 AM
Great DIY pics,
GammaTNT
10-31-2008, 07:22 AM
i just replace front and rear brake pads.
I believe i did it right. But something worries me.
i know there is a piston push the pads to stop.
But how does the pads unstick to the rotor when i let of of brake pedal??
can someone shine some light on this? Sorry if i T/J
fuzzymica
04-16-2009, 03:24 PM
appreciate the pics
kuo34
04-16-2009, 04:16 PM
My guess would be the spinning rotor "bounces" the pads off when the calipers aren't squeezing down. The pads aren't going to want to stay on a moving surface if it can be elsewhere in the housing. Or magic elves pull those pads back when you're not looking like the ones that turn off the refrigerator light when the doors close.
xroad2oblivionx
04-24-2009, 06:29 PM
This is a great DIY thanks! I installed my brakes without any problems. I didn't have a breaker bar, but jumping on the tire iron for a bit loosened up my lugs juuust fine :P
O5_TRD_tC
04-24-2009, 06:36 PM
np glad you saved a "few" bucks :P
SoulXquisite
04-27-2009, 04:45 PM
-yeah im going to do my brakes soon, starting to squel like a pig-
-how much were OEM pads-
O5_TRD_tC
04-27-2009, 05:09 PM
they costs ~$50 before tax
im not sure I get a discounted price. :D
SoulXquisite
04-27-2009, 06:58 PM
oh man hook ups are sick
no worries some where around like 60-80 bucks huh give or take.
SoulXquisite
06-16-2009, 08:38 PM
-ok so i know you use the 14mm on the top bolt, but what is the size of the nut that it screws into? cuz last time i just used some pliers, not the best way but it worked. needless to say my pads still look good at 45k (i find this wierd)?
Yanki01
12-09-2009, 11:53 PM
bringing this thread back. my tC has about 33k miles and the fronts need a change, the rears still have life. i ordered front and rear OEM pads from TRDSparks.com for about $90 shipped. damn good price if you ask me. local Toyota dealership quoted my $249 for the fronts, $249 for the rears, labor and pads only. pretty crazy, ill be doing this myself!
Yanki01
01-10-2010, 09:50 PM
just did the front myself, no need to spend the money if you have the tools. if not, rent them. seriously this brake job is cake! took me 30mins, thats with jacking up the car and removing the wheels. next week ill get to the rears, but i desperately needed to do the fronts. no fluid needed to be added nor did any come out. thanks for this DIY and saving $250+.
O5_TRD_tC
01-11-2010, 09:30 PM
np Yanki!
CSUnited14
02-08-2010, 11:35 PM
Doing mine tomorrow... one quick question i got the EBC green stuff and they came with anti Squeal shims.. do those replace the stock ones or they go on top of the stock shim/bracket?? shed some light for me please.. and elves dont like lights
kostnkost
02-18-2010, 04:18 PM
Wow how easy was this! I took my time and I was finished in an hour.
I hope the back ones are as easy as the front cause I noticed they are wearing thin as well. I guess once I see the brake fluid low again, it will be time to change them.
In reference to the above poster, I would assume those shims replace the top piece of metal once you take the pads off. Once you take the pads off, you will notice the position of the clips on the shims, and where they should go.
Good luck!
CSUnited14
02-18-2010, 06:48 PM
Yea i did my fronts are rear.. I used the existing metal brackets... Seems to done zero harm... I have a Small hint of squeal SMALL! lol but they are still being broken in and i did NOT turn the rotors. But that's causing the squealing I'm sure.
Overall I went with the EBC greenStuff I love them.. There basically grabbing as soon as i touch the petal which i love. This DIY was top NOTCH..
One thing though when i did my brakes i took the inner Part all the way off Consist of one more bolt on the bottom. The EBC's where thicker i needed the room.
kostnkost
02-20-2010, 10:33 PM
I was considering doing this as well, but my squeezed in. I also noticed a grinding when I make a right and left hand turns. Maybe it is just the bigger pads and the car has to get used to. I am sure they have to be worked in, but it is barely noticeable.
Domo
02-20-2010, 11:00 PM
can anyone explain to me how the brake system works? I have been wondering this since no one was able to give me a direct answer but only assumptions. Do both the front and back brakes lock on when you stop or somewhere along the lines of 60/40. For example the front brakes lock first, then the back brakes come on afterward. I always thought the front brakes were the only brakes that worked but recently I have been seeing plenty of owners swapping out their rear pads. On top of that, I know that AWD cars use the 60/40 ratio but is it the same for our car?
MeatRocket
02-23-2010, 06:39 PM
when you replace he brake pads for the first time do you have to get the rotors turned or re-surfaced???
ack154
02-23-2010, 06:47 PM
Not necessarily. You'd have to use your judgement on that I think. If you notice a lot of pitting or grooving - you might want to. If they seem pretty smooth overall - skip it. Just be sure to follow proper bed-in instructions for your pads.
kostnkost
02-24-2010, 03:26 PM
Is there a method to bed-in your brakes? I know I read somewhere that you should do it when there is little traffic(usually in the early morning) and that you have to go around 60mph and stop abruptly.
Anyone know the actual method?
ack154
02-24-2010, 04:26 PM
The manufacturer's actually have varying recommendations on this. Here is a list of the most common names and their procedures:
One of the key things here is that you do NOT come to a COMPLETE stop while bedding these in. Generally it is a few hard braking stints from 50-5mph or 60-10 or something like that. But definitely read through those above and you'll get a good idea.
ReticulatingPigeonElf
02-05-2011, 01:17 PM
someone drove my tc on ebrake for a few miles...might need to do this
YSD
03-25-2011, 02:41 PM
awesome
SoulXquisite
05-04-2011, 11:39 PM
-can't wait to do this tommorow! again-
divisii
05-05-2011, 12:49 AM
As malloy points out, this write-up ain't detailed. Step one is to safely lift the wheel ... blocks, ramps, whatevr backup keeps the car from falling on any1 while it's worked on. When done replacing brakes, start the car, pump the pedal a few times before driving, and stop soon to check the fluid. Drive slowly and carefully at first, in case the brakes are messed up.
With floating calipers, it is important to (clean, replace or) at least grease both pins. It is ill advised to touch the rotor with your bare hands, because any grease/oils can create stopping issues. Lastly, most good brake kits come with new backing plates, and anti-squeak; which is not grease. I have had best results from the spray on stuff, to quiet noise; and wiping up dust helps, too.
Re. what Domo said about f/r balance- Brakes have a check valve that typically varies the amount of pressure/force applied between front and rear. Not sure 100% if this is true for tC 'cause they actually have separate master cylinders. A manually adjustable system is often installed/used by racers.
As mentioned, it is a good idea to remove some brake fluid from the resevoir before pressing the piston, due to its very corrosive nature to paint. Brakes can gather water (and dust) over time, and it's a good idea to bleed/replace fluid; to get out any dirt, air or water. Kits are easy to find (even make). Make sure your at the right level before you call it a day.
A ghetto way of changing much of the fluid is to use a syringe/baster to pull out as much as possible from the resevoir, but not all the way so as to introduce air in. It's important to not touch the pedal during this and dispose of used fluid with a recycling facility! You can't expect to get it all clean, you get what you pay for.
ReticulatingPigeon- driving with the e-brake won't ruin your rears. the e-brake is an inner drum-style, that's separate from the disc setup. Your e-brake may be worn tho'
my pad platess are all rusted into pieces. Where can i get those plates? i don't remember if new pads come with them.
tc-guy
06-26-2011, 07:33 PM
i would get the factory ones. its called a shim kit. comes with all the shims and screechers for the pads. don't know the part number off the top of my head
GammaTNT
06-26-2011, 09:06 PM
i saw these pads on advance auto part's site. it said they come with shim.
Does that mean i don't need the stock ones?
https://lh3.googleusercontent.com/-0TpBqlig8ko/TgedyAtH3YI/AAAAAAAAB90/n1LgCSazNNM/s800/brake.jpg
GammaTNT
06-27-2011, 05:35 AM
i found a extra set of new Akebono pads for my dad's Camry. They have shim on them. So i don't think i will need to buy new factory shims.
Thanks again TC-Guy
othater
07-11-2011, 08:14 PM
(we have floating calipers, lube the guide pins.)
(With floating calipers, it is important to (clean, replace or) at least grease both pins.)
Anyone have a picture of the guide pins? and what type of grease.
I replaced the pads already. I should have read all the post before I put everything back together.
It was easy enough with this tutorial that I want to take it apart to grease the pins.
Thanks for the help. Saved me $$.
hypothesis
09-12-2011, 12:34 AM
Thanks for the write-up just did this myself, saved me a couple bucks :-D..
Azul
11-16-2011, 06:53 AM
Referred to this thread more than once. Thanks. I think I got it now.
nsx
11-29-2012, 03:42 AM
Reviving an old thread...
I am going to change front pads/rotors on a friend's '06 tC next weekend. The car sees 100% casual street driving so there is no desire to put high performance parts on the car. The pads will come from Autozone or OEM from trdsparks.com.
My question is about rotors...where do you guys usually buy them? Right now it is likely that I will get them from Autozone or NAPA. Are there any potential issues with rotors from these stores? Should I stick with OEM for the rotors?
