TYC taillights went out - FIX IT ticket
Old Jun 18, 2008 | 04:17 PM
yellowxboy's Avatar
Default TYC taillights went out - FIX IT ticket
So umm, last night i got pulled over because my tail lights were out. Thank goodness the cop realized that because I could've gotten rear ended or something. I searched the forums already and I know where the fuses are at (steering wheel and kick panel) so I will check them out later tonight when I get home.
Here is the problem:
When I hit the brakes, the TYC lights work fine, but when I am driving, the lights won't be on. Could that be a possible fuse problem? I am a little confused because the lights work when I brake though.
For those w/ TYC lights, its just the 2 reflector strips and the LEDs that are supposed to stay on right?
thanks in advance guys/gals.
Old Jun 18, 2008 | 04:27 PM
BlizZard's Avatar
your parking lights or headlights have to be "on" in order for the brakes to be "on" without actually braking lol
so....umm....did you have your lights on?
Old Jun 18, 2008 | 07:27 PM
ScionJim23's Avatar
yea, make sure your headlights are on. If they are then check the wiring and fuses over again. and yes, you have to reflector strips. the top part is the blinker, and the bottom are the lights/brake lights and reverse.
Old Jun 19, 2008 | 05:56 AM
yellowxboy's Avatar
LOL yes my headlights are switched 'on' .. and the reason i knew that my brake lights work is because i parked my car in reverse and saw the reflection when i sat in the car while pressing the breaks.
i came home late so i didn't have time to go under the steering wheel column to check the fuses :/
Old Jun 19, 2008 | 06:17 AM
breaux_tC's Avatar
if your headlights are on, the single LEDs in the TYCs should be dimly lit, if brake is applied there is a noteable difference in brightness
Old Jun 19, 2008 | 07:47 AM
ricexizxgood's Avatar
This happened to me before too. Check your fuses, it should be the parking light one.
Old Jul 14, 2009 | 05:08 AM
doper's Avatar
anyone figured out what caused the problem . i just got puled over for the same think. if so please let me know. also which fuse is for that? thanks
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
that_G_U_Ys_tC
Apr 9, 2015 05:07 AM
edwinisdumb15
Regional - Pacific South
Dec 9, 2014 11:20 PM
DJ_X_Trodinaire
67
Feb 11, 2005 04:38 PM
WhiteToaster
26
Nov 15, 2003 12:13 AM
