Mobil 1 synthetic
Old Jun 19, 2008 | 07:08 AM
Coolwaterz's Avatar
Default Mobil 1 synthetic
i just got the car last week. its at about 120miles so far.
after a few more miles is it ok to use Mobil 1 synthetic? 0w20? 0w30? 5w30?
or should i go for mobil 1 5000? (the conventional oil)
my friend said that if i go with synthetic my mpg will drop. is that true?
Old Jun 19, 2008 | 07:25 AM
TylerC08's Avatar
Lolzn...man your post whorin' it up.
Around 3,000 miles was when my engine seals finally set. I changed to Mobil 1 Syn 5w 20 around 4,500. Some think its safe to change right away while others think its safer to let the seals set before changing to synthetic. My gas mileage is about the same if not better. Keep replacing those oil filters with Toyota OEM. Search dude...search.
Old Jun 19, 2008 | 08:05 AM
Coolwaterz's Avatar
what do you guys think about the mobil 1 oil filters though?
and how do you know when your engine seals sets?
Old Jun 19, 2008 | 08:14 AM
tCtCtC's Avatar
im using a bosch oil filter cause it was $5 cheaper than the mobil 1.
for oil i use penzoil platinum synthetic 5w20. ive heard mixed reviews about mobile 1 though
Old Jun 19, 2008 | 08:25 AM
Coolwaterz's Avatar
i want to try royal purple =p. i guess when i hit the 10k mark i will...
Old Jun 19, 2008 | 08:40 AM
TylerC08's Avatar
I've heard bad stuff about mobile 1 oil filters with the size and the amount it can filter and return back to the engine. Mobile 1 oil filter is about a .5 inches shorter than a toyota filter. Every person on this site has their own favorite oil you just have to decide for yourself off the facts that are presented to you.
I checked my oil dipstick in intervals of 5 days since she came off the lot and noticed around 3,000 miles my oil level 'leveled out' and the viscosity had different characteristics within it. Your engine seals will begin to slow down on the absorbtion of oil(some notice it right away and for others it takes awhile). During this time some call it engine break in but the engine is pretty much good to go just read your manual for more info about break-in period because it's still important for new cars today.
Old Jun 19, 2008 | 02:04 PM
Coolwaterz's Avatar
the size difference in the filter has a minimal effect on the amount of oil you put in right? how much does a stock factory oil filter cost?
i worked at a garage before and those suckers are a nightmare to take off...not grip and the worst part some of them are so far in the engine tools could not be used...
i'll probably spary some adhesive grip on the filter before i install them....
Old Jun 19, 2008 | 04:51 PM
svrTc06's Avatar
i use royal purple, and k&n oil filter combo, and have been since i've been s/c. i had the dealer put mobil 1 synthetic in when they put the charger on, but at the next oil change, i switched to royal purple.
Old Jun 20, 2008 | 05:22 AM
Edmond's Avatar
I wouldn't use Mobil 1, I think it's junk. Go with Pennzoil Platinum, that's a pretty good oil. M1 seems to burn off quite quickly.
But I think their filters are decent.
Don't just get something because it's cheaper. You might change your own 3-4 times a year? Saving $15-20 a year on a cheaper filter isn't worth it, IMO.
Old Jun 20, 2008 | 05:32 AM
Coolwaterz's Avatar
lol what are you talking about? pennzoil is like the cheapest synthetic oil....
im really thinking about getting royal purple. but i'll probably have to order it online since i cant find any stores that sell then 0w20 or 5w20.
Old Jun 20, 2008 | 05:39 AM
Edmond's Avatar
Sorry, I was talking about the filter. Definitely spend the extra money to get a better filter.
Old Jun 20, 2008 | 05:42 AM
Coolwaterz's Avatar
whats a good oil filter?
Old Jun 20, 2008 | 05:43 AM
tCtCtC's Avatar
my bosch has been holding up fine
Old Jun 20, 2008 | 07:22 AM
TylerC08's Avatar
Are these statements engine specific or generalized over various engine makes towards M1?
Old Jun 20, 2008 | 07:29 AM
TylerC08's Avatar
Toyota OEM. They designed the engine.
Old Jun 20, 2008 | 10:35 PM
tkevin07's Avatar
good oil filters are OEM, K&N, Mobil1, Amsoil, and purolator
i use the K&N and mobil for m car because i use my car at high RPMS and i push it along with synthetic oil
if u drive normally use OEM, purolator or amsoil with regular oil
if u sometimes push it use synthetic
i used to have a honda and seen the difference of an enigne being pushed to its limits with synthetic oil and regular oilm, the synthetic can hold up to heat and the regular oil leaves burnt residue in the camshafts and uunder the valve cover
Old Jun 22, 2008 | 04:24 AM
Spicy_McHaggiz's Avatar
Exactly. Why chance other filters that make claims when you know the OEM will protect your motor? Sure one may be cheaper BUT it might come at engine safety.
I'd wait till your first oil change to switch over to Syn. Oil.
www.bobistheoilguy.com to research all your oil needs. I've not heard a whole lot of good about Royal Purple except that its pricey.
Old Jun 23, 2008 | 12:47 AM
Steventc07's Avatar
i use oem filters and castrol syntec, but thats just me
Old Jun 24, 2008 | 02:09 AM
ElevationTC's Avatar
My lifters are louder with mobile one.. I just switched to non synthetic.
Still use mobile oil with oem filter!
No matter what oil just make sure you do changes every 3-5k and check it every fill up and you will be OK.
Old Jun 24, 2008 | 10:01 PM
Hudnut's Avatar
Wrong answer. I went 15,000 miles on last oil change. The oil was amsoil 0w-30 with the amsoil eA oil filter changed filter only once. Had an oil sample sent for analysis and it came back just fine. could have gone further.
