Spacer Fitment
Old Jun 20, 2008 | 11:04 PM
Awwsnap's Avatar
Default Spacer Fitment
Ok, a 16x7 40mm offset wheel. Should 15mm hub spacers do the trick or should it bump up to 20? Also, would you recommend 5mm for the front or do you think it will still look good?
Old Jun 21, 2008 | 11:35 PM
bB2NER's Avatar
Music City Scions
The rears need 1/2 inch spacers to match the fronts. PM Mike (AllianceAutoSports), he has them for under 50 bucks shipped.
Old Jun 22, 2008 | 02:16 AM
Awwsnap's Avatar
Is there a big difference between the hub spacer and something like a H&R wheel spacer?
Old Jun 22, 2008 | 02:30 AM
bB2NER's Avatar
Music City Scions
I believe the wheel spacers require longer studs and they place more stress on the hub bearings. The hub spacers simply move the whole wheel assembly outward.
Old Jun 22, 2008 | 06:07 AM
Awwsnap's Avatar
Awesome, one final question for you. I'm gonna run a 205/50 series tire; will that 1/2" spacer rub with those or should it do all right?
Old Jun 22, 2008 | 12:49 PM
bB2NER's Avatar
Music City Scions
I'm not sure about that. You should be fine but don't quote me. The tire size is the same height but slightly wider than the stock 185/60/15s. You might want to do some measuring first.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
reniculous1
Aug 14, 2015 03:16 PM
