Adjusting Headlights After Lowering
Old Jun 21, 2008 | 05:56 PM
REaL's Avatar
Default Adjusting Headlights After Lowering
Is re-aiming of headlights required after lowering? I know most people don't do it but it seems that it would make sense, lower car would cause the beam to be lower. Any inputs?
Old Jun 21, 2008 | 06:01 PM
Metro273's Avatar
It makes sense to re-aim the beam a bit upward cause you don't want the beam to be under the vehicle that's in front of you...
Do you really wanna see the dirtiness under the car in front of you!
Old Jun 21, 2008 | 06:04 PM
REaL's Avatar
Well... depends what dirty car is in front.
Old Jun 21, 2008 | 11:05 PM
Sciontistical_One's Avatar
If your ride was level before the drop and still level after the drop, you should be okay.
If your ride is higher in the back than the front, or vice versa, your ride is not going to be level and therefore it will affect the angle at which the headlights are pointed. At that point you will need to re-aim your headlights to compensate.
I threw my coilovers in and the rear was riding a little high causing the headlights to point a little low. But instead of aiming my headlights, i just lowered the rear to level it out with the front. now my lights are pointed perfectly with the cutoff landing approximately at the top of most car bumpers.
evolving_machine
Oct 21, 2023 01:16 PM
TheTripleC
Jan 4, 2015 06:46 PM
minter66
Dec 15, 2014 01:45 PM
Opr8r
24
Jan 13, 2004 09:26 PM
