"race" shifting
I'm relatively new to MT but I'm getting the hang of it. I didn't really know of a good way to put the term but when accelerating hard and shifting at 5700rpm the tires will loose grip and screach. This is usualy only from 1st to 2nd but sometimes from 2nd to 3rd.
What I want to know is: Is this a result of poor shifting or is that just how it is? If it is because of shifting, on my part (which it probably is), then how do I stop the tires from loosing grip when I shift to second?
It would be very helpful if someone could explain the correct technique/method to me sense it's hard to tell me what I'm doing wrong when you can't see me.
From my understanding is that chirping the tires when shifting is actually a good thing because it's the engine's sweet spot where it produces most/all of it's power, and when it shifts, it has so much that it makes the tires chirp.
Chirping gears doesnt really mean your a great driver. With a new clutch anyone can do it.
It means your keeping the momentum of the motors power, as well as fast shifts and fast clutch release.
I can spin all 2nd in my Mx6 :D
No chirping for me.
No chirping for me.
Yeah, 260hp (or was it 240?) will help with that ^_^. I actualy have never gone for a full burnout at high revs yet. I'm interested at what the tc can do as far as burnouts, but I'm also scared to put the car through that sense I don't know exactly what I'm doing. Most I've droped the clutch at was 3k rpm.
Not to say that this is the right way, but it's the way I do it.
Rev to around 2.5-3k rpm and when it's time, drop the clutch (release clutch and hit full throttle). It's all pretty self-explanitory from there. Just keep on the gas and shift quickly through the gears. Oh, and make sure you shift at 5700rpm each time.
This is assuming your tC is stock.... and manual. If it's automatic then just rev to about 3-4k in neutral, switch to D, hit the gas and hope for the best?
cool thanks wen u mean drop the clutch is it like bam and all the way out? or is like rev then go barely before friction point and slowly move it out, will it bog if u just drop it instantly? sorry guys im just in a learning process, im 16 and had this car for a month and almost hit 1000 miles on it, wanna have some fun wiht it
"Yeah, 260hp (or was it 240?) will help with that ^_^. I actualy have never gone for a full burnout at high revs yet. I'm interested at what the tc can do as far as burnouts, but I'm also scared to put the car through that sense I don't know exactly what I'm doing. Most I've droped the clutch at was 3k rpm."
burning out with this car is pretty impressive, espcially considering it is a front wheel drive
why 5700??? and why 2.5 or 3k???i hit that bad boy 4 or even 4 half and pop the clutch...and shift at 6200 if you ask me shifting at 5700 you are losing alot of power...the vvti opens around 4k so you probably be dropping the needle pretty far down if you aint powershifting...
Well the peak hp is at 5700, so after that you get less torque than you would get if you were to shift. I haven't really taken vvt-i into consideration because I don't know what it does but like ScummyMcOwnage said, dyno readings show that power drops off after 5700 anyway.
Originally Posted by ScummyMcOwnage
I got a question for you, how much do your tires spin when you do that? I know if I pop the clutch any higher than 3K, I'll get wheelspin.
you want to shift around 6k yeah you get max power at 5700 but you want the next gear to be higher in it's powerband so when you shift at 6k you're still making more power then you would if you shifted at 5700 and started the next gear lower in it's powerband. now i'm no expert this is just what i'v noticed from my experiences, if i'm wrong someone please correct me
"you want to shift around 6k yeah you get max power at 5700 but you want the next gear to be higher in it's powerband so when you shift at 6k you're still making more power then you would if you shifted at 5700 and started the next gear lower in it's powerband. now i'm no expert this is just what i'v noticed from my experiences, if i'm wrong someone please correct me"
i think you're right. i've always noticed that too.
