Pulley with turbo?
Im auto at 6 psi right now about 242whp im lowering it to 5psi so itll be around 220-230whp .. if i put a NST or agency pulley on is it safe? what wud the effects be?
Originally Posted by SoFloTC
so it wont affect anything at all? wont my rpms climb faster though?
in gear, though, that's a common misconception. if it really made your RPMs climb faster in gear by a noticeable amount, that means you'd be accelerating a good amount faster. seeing as how these pulley mods are often overhyped and may add 2-3hp at the most, it's just not gonna happen. not saying it's a bad mod; just don't put it on and expect your car to rev like a bike.
as for the turbo, the two are completely unrelated. it will not affect the turbo at all.
Throwing off the balance of a crankshaft is not good - and the more hp and rpm you run the worse.
Just imagine a non-perfect circle rolling on the ground.. the faster it goes, the more erratic the motion is.
There's been tons of cases where people damage their motors by changing their crank pullies or removing stock harmonic balancers. I'm not sure how it applies to our specific motor, but I'd rather stay away than pick up that 2-3hp and possible engine damage.
a lightweight crank pulley should be okay, its still balanced but with less rotational mass. underdrive pulleys are where you'll run into problems (correct me if im wrong this is from what i've learned)
Originally Posted by xdejablu3x
Originally Posted by SuperXero
Originally Posted by Rydrdg
it will help you get off quiker
It will not ill effect your crankshaft. When those pulleys are turned on a lathe they come out true and balanced.
As for gains...maybe 5-6HP, but you will not even feel the benefit after your turbo upgrade. If you want a new shiny part I would go for it
Yes, there is about 2% of people out there with problems, but I honestly think that has to do with the install. I bet if they just torqued it down to the mfg's specs they will have no problems. There is a MEGA thread about pulleys and the majority of people love them and have no side effects.
Go with the AP one.
Go with the AP one.
NonStopTuning
Jan 20, 2015 05:20 AM
