Optima Battery
Old Dec 7, 2004 | 10:53 AM
Chipper's Avatar
Default Optima Battery
I am looking to get a Red Top Optima Battery for my xA and I need to know which model number to get. It is not listed on the Optima website... Is there a particular one that I should get, or just go by the physical size of the battery?
Thanks in advance
Old Dec 7, 2004 | 02:38 PM
grnxb's Avatar
I would imagine you would go by physical size/cca's. I don't think there are too many different red tops, so it shouldn't be too hard. Good luck
Old Dec 7, 2004 | 03:52 PM
SWF_05_tC's Avatar
I use a redtop in my xB, 925 cca's I believe. Works great. I've got a 1000 watt system in the back and no headlight dimming :-)
Old Dec 7, 2004 | 10:33 PM
fireballfish's Avatar
Why red top? why not yellow top?
Old Dec 7, 2004 | 11:11 PM
SWF_05_tC's Avatar
Yellow tops are deep cycle generally, meant as a second battery for simply powering extra accessories and equipment (like hydros or airbag setups, extreme car audio eqiopment, etc). They have adverse effects on your stock charging system when the vehicle is in use, thus giving the redtops more actual effectiveness in cars in which there is only one battery.
Old Dec 8, 2004 | 12:12 AM
Munch's Avatar
Where did this info come from :?: Not saying that you're wrong. I'm just curious :?
Old Dec 8, 2004 | 02:35 AM
SWF_05_tC's Avatar
From Optima.
Old Dec 8, 2004 | 02:51 AM
Munch's Avatar
From Optima.
You got a link :?:
Old Dec 8, 2004 | 02:55 AM
J_A_Trevino's Avatar
i am also considering getting an optima but not sure if im going to go with a red or yellow top, does anyone who has one have a part # or something to go buy for the size?
Old Dec 8, 2004 | 03:04 AM
oneslowxa's Avatar
what SWF 05 tC says is true, if you use the yellow tops for a daily driven car there's a good chance that it won't last longer then one year without having to be replaced if you constantly push your charging system...
both yellow and red tops are awsome batteries but they are designed for different purposes...
Old Dec 8, 2004 | 03:12 AM
SWF_05_tC's Avatar
From Optima.
You got a link :?:
If you call them up they'll be more than happy to explain it to ya :-). That's what made me decide to get my redtop. Unfortunately I don't have a direct link. I will however get you guys the part number for the battery I am using in the morning when I go out to the car.
Old Dec 8, 2004 | 03:15 AM
could you get the part # off of it? we sell them at work and several differnt sizes, what size wire are you using for your system?
Old Dec 8, 2004 | 03:19 AM
SWF_05_tC's Avatar
Look up, lol. Yeah, I'll post it in the AM for you.
Old Dec 8, 2004 | 03:22 AM
squirrel's Avatar
Ok, let's say I get a red top, then how would I hook up a yellow as a back up?
I know absolutely zilch when its comes to something like this. Plus I need a cap on my 1k watt amp cuz my lights dim when the bass is deep and hard hitting.
Old Dec 8, 2004 | 03:29 AM
i think you would use a battery isolator which will send a charge to both batteries, i also have the dimming problem tried a 1 farad cap and zilch.
Old Dec 8, 2004 | 03:35 AM
SWF_05_tC's Avatar
A battery and alternator will do much more than a cap for the dimming problem. Actually the Optima took away from the dimming headlights that I had when I first put the system in. The cap can only recharge so fast.
Old Dec 8, 2004 | 04:24 AM
windowtint's Avatar
Red Top (which is what I have) - I think there's a picture of when it was still 'newly installed' in my 'WWW' link below. Yellow Top (as said) is not meant for use as a normal everyday battery - it's a spendy battery to be replacing every so often. They also make the BLue Top (marine battery) that is a very deep cycle - some use it isolated as an 'assistant' in serious audio set-ups. I'm not convinced that it's of any advantage over Yellow though.
Anyhow - the battery (if Optima is your choice) you should at least start out with is the Red Top. There are others on the market though - if you're really looking becuase of A/V requirements, a good one is BatCap (they're local to me, sorta... short-ish drive) They make a hybrid battery/Capacitor type battery - a popular battery in SPL sound-offs
Old Dec 8, 2004 | 11:02 AM
Chipper's Avatar
Thanks for the feedback. The reason I was going with a Red Top Optima is because my xA is my daily driver and I can get one from Costco for $100.
I guess as long as it is the proper dimentions it will work fine then?
Appreciate it.
Old Dec 8, 2004 | 06:15 PM
Dred504's Avatar
SW 05 tc,
Are you running a red top and a cap with the stock alt? or just a red top with no toher additionns?
Thanks
Old Dec 8, 2004 | 08:46 PM
SWF_05_tC's Avatar
Just a redtop. And I forgot to post the model of the battery this morning. I'll do that tonight.
