Enkei RPF1 Black .... is it worth it 6 lbs lighter than stoc
Im thinking about getting 17*7.5 lightweight rim for performance reasons, these rims are 6 lbs lighter than stock but ...
how much of a real difference does it make in wheel weight is there some kinda equation like every 1 lb added to rim is like really adding 5 lbs to the car, 10 lbs to the car?
6 lbs less * 4 = 24lbs less in wheel weight total
24 * 5 = 120lbs ... which is like .1 off 1/4 mile .... not really worth it if every lb is like adding 5 hmmmm anyone know the real scoop
If I remember right...1 lb of rotating mass is equivalent in speed reduction to 6 lbs of stationary mass. I could be wrong, but I think I remember reading a post from Otocan about it a long time ago. Take it for what it's worth. I could be completely wrong...I might be right...who know's...lol
Originally Posted by Farcus001
if you race definitely, if its your DD that'll be retarded.
I have the 16 inch Spec steelies which are lighter than the 17 inch stockies and you can definitely tell the difference. Even on the street where you're just accelerating into traffic on the freeway.
The car is "peppier" in the get-up-and-go department. I didn't care for the way they look, but there is a noticeable difference.
Originally Posted by ricexizxgood
IMO they're worth it. I also got a slightly better gas mileage when I had that setup.
http://www.tirerack.com/upgrade_gara...=Black+Painted
I think these would look pretty nuts on my car because its SuperWhite with carbon fiber hood, and tinted tailights, and black sidemirrors!!!
Im running 225 45 on the stock 17's because these are 17*7.5 could i run 235's since they are an extra 1/2 inch wider??
wwwoooowwww the motegi track traklites weigh only 14 lbs!!!!! Look pretty awesome too
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Ha just found out my khumo spt's weigh 24 lbs ... Michelin pilot sport ps2's weigh only 22 lbs ....
so my stock rim 21lbs + 24lb khumo tire = 45 lbs total
motegi rim = 14lbs + 22lb michelin tire = 36 lbs total
wow i could reduce each rim + tire by 9 lbs ... 36 lbs off 4 rims
if each 1 lb rotational mass = 6 lbs stationary mass 36 * 6 = 216 lbs
not bad not bad!!!!!!!!!
Originally Posted by jblaze4lif
What are some other lightweight tires besides the Michelin pilot sport ps2's which weigh 22lbs .... 225/45/17s
Here are some High Performance tires with comparable weights. (Weights are according to manufacturers)
Kumho MX 215/45-17 = 20.0 lbs
Goodyear F1 GS D3 215/45-17 = 22.36lbs
Falken 452 215/45-17 = 23.2lbs
*The Kumho MX is a tire built for the Track, they have a soft sticky compound, out of the three above they are the most dry performance oriented. The F1 GS D3 is an amazing everyday performance tire. A lot of the big bodied muscle car drivers swear by this tire for its everyday performance and wet traction. The Falken 452 is an affordable everyday performance tire. This tire offers a lot of performance for the price.
The Nitto NeoGen also appears to be light as well. It should fall in the 21-23lbs range. Let me know if you are interested in it and I will get a specific weight for you. The NeoGen competes very close to the 452.
-Travis
