Wierd Clutch Problem
Old Jun 28, 2008 | 08:52 PM
whippingpost's Avatar
Default Wierd Clutch Problem
I went to start my car after work the other day and my clutch pedal was resting on the floor! I pulled it back up with my hand and pushed it down and it just stayed there. This has never happened before, so whats going on? Can anyone shed some light on this for me?
Old Jun 28, 2008 | 09:08 PM
MrBurrito's Avatar
you shouldcheck yor clutch line and your brake fluid...it sounds like you might need to bleed your clutch sytem
Old Jun 28, 2008 | 09:32 PM
I bled the clutch the next day and it did the same thing
Old Jun 29, 2008 | 12:32 PM
swiber's Avatar
If the fluid level is good then i would want to say the clutch master cylinder bit the dust.
Old Jun 29, 2008 | 12:53 PM
NateV's Avatar
Sounds like you need to upgrade your clutch, a new stage 2 with a light flywheel will do just fine! But yeah you master cylinder sounds like its bad.
Old Jun 29, 2008 | 01:53 PM
crush02342002's Avatar
op is there any other problems with your clutch other than pedal being on the ground.
Old Jun 29, 2008 | 02:03 PM
I just went out to look at mine thinking it may be the return spring poped out or something but after looking i dont think thats your problem, sorry i know im not much help....lol
Old Jun 29, 2008 | 02:24 PM
Blue_TC_Man's Avatar
could also be the slave cylinder
Old Jun 30, 2008 | 04:04 PM
Ok guys here is an update. My first thought was the master cylinder, so I ordered one and it will be here Tuesday. Hopefully that will fix it. My clutch is a competition clutch stage 2 with a zpi 9lb flywheel. Great combo by the way. I'll let you guys now what happens Tuesday. Keep the suggestions coming. Thnaks for the help.
Dmmcclair
Aug 13, 2015 07:14 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
yhwhdesign
10
Feb 6, 2015 05:00 AM
baker08tc
Dec 30, 2014 12:02 AM
tC4me
Feb 5, 2004 02:30 PM
