TcNY
06-30-2008, 12:27 AM
I've been having trouble with my car pulling to the right as Ive been driving. Originally I had a bad tire that would always get very low and cause the car to pull, this I believe led to the trouble, and meanwhile I looked into the tire getting fixed till I could get new tires. Well, no leak was found and until I could afford new tires I kept putting air in this one. I recently got the Falcon Tires and the problem was a little better, but not fully.
So today I go to Sears and get the wheels aligned (which was needed) I have the print out sheet and what they did to adjust the angles, but as I was driving home I notice my car still going right as I let go of the steering wheel. So Im not sure what the problem is. This is just agrevating.
I can scan the sheet or perhaps type the numbers out later on, but one problem with the printout sheet was the SAI. On the front right tire it is 13.6 degrees. The range next to it says 11.8-13.3 degrees. I feel like this could be the problem and I asked why those numbers were still red and they said they do not fix SAI. So my question is is this the problem? All of the other numbers on my sheet are green, in the recomended range. Before the alignment there were about 8 red numbers.
The only red numbers now, that are not in the range are Front right SAI, Front Cross SAI, and rear cross camber. Rear cross camber is -.7degrees while recomended is -.5 to .5 degrees. Front cross SAI is out of range at -1.6 degrees
Thanks a lot I appreciate it!
