--- Won't Start! Alternator Apparently Over Charging---
Old Jul 3, 2008 | 04:37 AM
dmpsk8's Avatar
Default --- Won't Start! Alternator Apparently Over Charging---
OK, so last week my car decided not to start when i was on my way to work. i gave key a turn and all i got was a click and an electrical hum. Jumped it and it drove fine for about a week.
Today i went to start it and the same thing happened. I was initally hesitant of blaming the battery since the lights didnt seem to dim when i attempted to start her up. I was leaning towards a starter problem. But, today i turned on my engine bay lamps (dark out) and they lost power when i was attempting to start it. I thought i was kinda weird that the lamps indicated a weak battery signal, but the dome, gauges, etc. didn't.
Now my car did spend a few months in cold storage for the winter. Lazily, I left the battery in for much of the time span. The minor use/cold could have shortened the batt's life, which i am just now seeing the effects of. Since I have ground wires, i checked all the connections to the battery for snugness - all passed. I'm gonna have the battery checked tomorrow. The alternator crossed my mind tho i HIGHLY doubt it could be bad already.
If the battery is indeed bad, it seems weird that it held up good for a system bumpin' week before it ran outta juice again.
Any input to point me in the direction of the problem is welcome , thanks.
Old Jul 3, 2008 | 10:40 AM
Maguyver's Avatar
at first it sounded like a loose negative but you checked it and it was fine so...... I would start with the battery
Old Jul 3, 2008 | 01:34 PM
dmpsk8's Avatar
we'll see about the battery today. hopefully thats the problem
Old Jul 3, 2008 | 10:59 PM
dmpsk8's Avatar
update:
Had some testing done:
Battery = Good
Alternator = Good...but way overcharging
Luckily I have a guess as to the culprit. I think my voltage stabilizer is screwed up(fairly low end part) and throwing the charging outta wack. I pulled it off today to see whats gonna happen. Hope its a fix, but who knows.
Old Jul 6, 2008 | 04:35 PM
kzhorse's Avatar
Strictly Scionized
Any way to just get the regulator from a parts rebuilder?
places like this
http://www.nationsautoelectric.com/altparts.html
Scott
Old Jul 6, 2008 | 07:34 PM
dmpsk8's Avatar
i assumed i wouldnt be able to. might have to look into that if i keep having issues
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
Al-Truistic
Jan 14, 2004 06:32 PM
Al-Truistic
12
Jan 9, 2004 11:37 PM
scionspecialistvegas
Dec 15, 2003 11:21 AM
