Noob Help! ( With Wire taping)
I am having some trouble figuring out how to tap power from the cigarette lighter.
What exactly do you mean by this? I see it in many DIY threads, mostly in interior LED mod threads.
From what i understand it means to cut the wire, split the interior copper/iron or whatever the wire is made of, and then attach one to one wire and the other half to the wire that was cut.
I have a few questions, is there an alternative way thats easier? I'd hate to fish a wire from the engine bay for some leds and cathodes.
Would doing this harm the cigarette lighter? I use it for my radar, so messing it up would leave me radarless :X.
Do i loose power when splitting the wire?
Thanks, and sorry for all the questions.
or u can to it my ghetto way,
Strip the wire by tool or a razor blade,
twist the 3 wires together.
and cover it with some electrical tape.
I did that for my radar detector, and amp remote turn on wires.
You can get insulated fork/spade terminals that can be crimped easily using pliers for a professional, safe, and reliable connection:
Or at least, please use a wire tap or wire nuts instead of electrical tape! After a year or two, the adhesive will wear off and could cause a short if it bumps into another uninsulated conductor.
I'm sure it's reliable enough for use in a car. Wouldn't be broken down by heat or anything.
A crimp in a terminal would last longer, I would think, but a tap is simpler and cheaper probably.
What did you try to use it for? Maybe an amp would draw that much current, but it sounds like he would want to be using it for LED lighting, which draws very low current. It would be ok.
I can see how the melting could occur, many of these are probably made of very bad plastic.
btw, if you have any local alternatives to Radio Shack, I suggest checking those. Most decent sized cities have some sort of wholesale/just large electronics supply store around that are much cheaper than Radio Shack. The prices of Radio Shack are usually pretty high, but many times are the only local option, so check around
Originally Posted by jsingh
this thread is kinda half way died..
but i have a question if i use 1 cathrode kit and about 4 leds...and power em from cigar/12v output...would it be ok?
I'm one of those other people who brought the wires in from the battery, put them to a circuit block, then distribute using spade connectors to switches and various other lighting knick knacks....
do u think i should get 5amp fuse and 16 gauge wire fuse holder from oznium?
or 3 amp.
(i will be doing a cathode kit, 2-6 led lights)
thanks..
