View Full Version : xB: WOW! New Shocks and RSB
douglasinct
07-04-2008, 10:14 PM
My Box:
2005 xB
58,000 miles on it
JUST WOW!
Just changed the OEM shocks for the Monroe Sensa-Trak 5987 shock, and added a Progress Rear Sway Bar (RSB) this afternoon.
WOW!
The Monroe 5987 shocks make the xB much more comfortable going over bumps and the average road surface. :)
WOW! WOW! WOW!
The Progress RSB keeps the back from indicateing its desire to to a full aircraft roll on the curves (e.g. exit ramps from the Interstate), and lets me know that I AM riding on RADIAL tires and not Bias Ply. :D
- I had no idea radial tires could be so effective! :clap:
If you do nothing else to your Gen 1 xB, DO THESE TWO THINGS!
(PS. Both are VERY EASY to do by yourself.)
NEXT:
New McPherson Struts up front, and a GREDDY Strut Tower Brace.
- I "might as well" do the strut brace while I am changing out the OEM Struts with the Monroe 72245. :D
xBHAWK
07-05-2008, 02:53 AM
My Box is 2005 with 78,000 miles.
I did the same thing with the rear shocks and added that Progress Rear Sway bar myself. Easy mods to do and worthwhile.
I went with the DC strut tower bar up front.
Are you going to install the energy supression (suspention) front sway bar end links? That $20 mod is a must for that beefy front sway bar with the wimpy OEM end links. See the differance below:
http://img63.imageshack.us/img63/9744/20060730bushings0008eb3.jpg
See the D-I-Y pictures that starts on page 7 of this thread:
http://www.scionlife.com/forums/viewtopic.php?t=78651&postdays=0&postorder=asc&&start=40
douglasinct
07-05-2008, 01:44 PM
Just took the car over to McD's this morning for Breakfast.
To get there, I take a road that becomes three lanes in going my way.
Then, the right lane veers off to the right and the other two make a HARD curve to the LEFT as two other lanes join the road on the right.
Normally, with the car in either of those two left lanes, there is a tendency of a forced drift into the adjacent lane the right. This makes for some quite interesting encounters with other inept drivers.
NOW, my car stays PLANTED in the the lane I'm in as I curve left. :clap: :clap: :clap:
douglasinct
07-05-2008, 01:48 PM
See the difference below:
Thanks for the suggestion. :)
I need to read more about this topic of "end links".
- Right now I don't know what they do, or where they would be found on the car . :ponder:
But for $20... I am certainly going to find out! :D
Sciond
07-05-2008, 02:19 PM
hmm can you post this 30 more times???? nice job though
bB2NER
07-05-2008, 02:25 PM
Told Ya So! Now do the fronts and you'll be all set.
douglasinct
07-05-2008, 02:26 PM
Just went to your DIY instructions on Page 7 of the link you provided. :clap: :clap: :clap:
Hint:
Don't bother reading the preceding SIX PAGES. :nope:
Now I KNOW where these things go. :D
AutoZone (bushings)
Lowes (Hardware - "C" Grade) ...
here I come! 8)
jct
07-05-2008, 05:14 PM
were you really riding on bias ply tires???
only good those tires are good for is burn out contests cause they smoke alot from what i've heard
i still have two bias ply tires from the 80's off of my old car...
douglasinct
07-05-2008, 09:34 PM
No, not at all. :)
The Before and After contrast was like changing from Bias Ply to Radial tires. 8)
bmph8ter
07-20-2008, 11:18 PM
Cool. How hard was it to put on the swaybar? Any clearance issues with it?
jct
07-21-2008, 12:15 AM
the rsb is easy at most a 20 minute job
bB2NER
07-21-2008, 02:52 AM
2 holes are already there and 2 more need to be drilled then it's just bolt it on and go.
365Motorwerks
07-21-2008, 05:21 AM
The newer bars don't need drilling so it's super easy that 20min estimate isn't even rushing it!
Tip on installing the bar... run a couple long zip-tys (or a few short ones coupled together) around the rear beam and sway bar to keep it in place while you line everything up!
bB2NER
07-21-2008, 05:39 AM
Tip on installing the bar... run a couple long zip-tys (or a few short ones coupled together) around the rear beam and sway bar to keep it in place while you line everything up!Oh ok, good to know. I have a Whiteline bar so I didn't know for sure on the Progress and TRD.
DiStUrBeD_AzN
07-23-2008, 11:49 PM
Where do I get these shocks for my 06 xB? The ride is very unsmooth!
