JL W7
Old Dec 8, 2004 | 11:40 PM
ProjectFusion's Avatar
Default JL W7
Anyone have a 13.5 JL W7 in their Scion? If so how does it sound also what kind of box did you build for it and how much room did it take up. Thanks in advance.
Old Dec 9, 2004 | 01:31 PM
JLTD's Avatar
You can get the enclosure information here on page 7: http://www.jlaudio.com/subwoofers/pdfs/13W7_MAN.pdf
The 13W7 is the largest woofer JL Audio manufacturers. It's high efficiency requires a large enclosure as well. It's going to take up alot of space (especially ported). If space is in short supply, check out the 13W6v2 http://www.jlaudio.com/subwoofers/13w6v2.html
The best thing to do when selecting a woofer is to first determine how much space you have to work with and then select the woofer that works best within that space. Too many people buy first then try to shoe-horn the woofer into an enclosure that is too small. The results are not favorable especially when dealing with high efficiency designs like the W7. A small woofer in a proper enclosure will out-perform a large woofer in an enclosure that is too small.
Old Dec 9, 2004 | 07:53 PM
Knowing the back of the XB what would you suggest for a nice sounding low note quality bass. I'm wanting to stick with JL but I'm not going to be doing any SPL's or things like that. Just want something that's loud and has a good quality to it.
Old Dec 9, 2004 | 11:53 PM
aarontrini85's Avatar
if your lookin at doing a w7 you should get a hold of rockdezzo he is usealy on the greatlakes area fourm he has a w7 in his xb running a sq setup and it is f*cking nice
Old Dec 10, 2004 | 04:23 AM
VtScionGuy's Avatar
If not into extreme SQL, which is what the W7 is for then go with the above suggestion of a W6v2. Or heck get an ID Max for much less. The ID Max will sound better than the W6v2 and around the same price too.
Of course if you have money and can sacrifice space then go for it. I had 2 W7's previously and they were awesome, although a 13.5 is a bit extreme.
Old Dec 10, 2004 | 01:34 PM
JLTD's Avatar
A review of the 12W6v2 by some big players in audio: http://www.jlaudio.com/subwoofers/pd...6v2_Review.pdf
All of the W6v2s will have the same sonic signature, the difference between them will be output potential.
Old Dec 11, 2004 | 03:43 AM
tckurt's Avatar
N.G.S.O.
the w6v2 is practically just as good for about 100-200 less
Old Dec 15, 2004 | 07:35 AM
ljthegr8's Avatar
yes, a w6 is just as good..actually, alot of the bass depends on the dimensions and quality of your enclosure.
Old Dec 15, 2004 | 01:41 PM
anyone know good spot to get two W6's plus amp?
Old Dec 15, 2004 | 02:20 PM
oneslowxa's Avatar
Check your local area... They will give you better service and warranty the products...
http://jlaudio.com/dealerfind.cfm
Old Dec 15, 2004 | 06:36 PM
all of my local shops charge out the ___. That's the problem with living in an area where average income is over 100k
Old Dec 15, 2004 | 07:25 PM
VtScionGuy's Avatar
hmm bunch of @$$es lols, then go buy a used one off a cr audio forum like carsound or elitecaraudio and etc
not worth paying retail for anything now a days, if I were you i'd seriously consider an ID Max for the same price as the W6 retail
Old Jan 5, 2005 | 11:52 PM
badtouch's Avatar
Default JL audio
try acaraudio.com. they have some decent prices from what ive seen shopping around on the net
Old Jan 6, 2005 | 01:35 AM
Max2k's Avatar
eBay? I got pretty much my entire system off there.
