Is sat. radio adjustable for sensitivity?
Old Jul 8, 2008 | 08:05 PM
Maytag's Avatar
Default Is sat. radio adjustable for sensitivity?
Hi gang,
I have the sirius factory system in my 08 xB. I bought it through Sparks, and installed myself. I'm getting more cutouts in the music than I think I should I installed exactly as instructed, with the sat antenna behind the roof antenna. Is this unit at all adjustable for sensitivity? I know tree cover is prevalent now, but I still think I shouldn't get so many drops. Ideas?
Old Jul 8, 2008 | 10:45 PM
detroitbassxb's Avatar
It isn't adjustable, no. But ti definitely sounds like there is a problem. The only time mine ever cut out was when I would go under overpasses on the freeway. Trees shouldn't affect it.
Old Jul 10, 2008 | 10:58 PM
whiteboyslo's Avatar
there's no setting you can really play with. your best bet is to play with antenna location, although the location you have it in now is about as good as you're gonna get.
Mike
Old Jul 11, 2008 | 01:03 PM
Maytag's Avatar
Thanks for the replys, guys.
I seem to get drops when I'm under heavy tree cover, but sometimes I also get a "No Signal" screen for several seconds when changing channels, before the new channel starts actually playing. This doesn't happen all the time, just sometimes.
Old Jul 11, 2008 | 03:27 PM
memebag's Avatar
That sucks. I've got a TOY-SC1/SCC1 plugged into the back of my premium head unit and my antenna (a really good one from an old Starmate) mounted on the back of the roof and I think I very rarely get drop outs. There have been some threads on Sirius Backstage about the newer, circular antennas failing due to corrosion inside. Which antenna do you have? Which satellite tuner?
Old Jul 11, 2008 | 05:22 PM
Maytag's Avatar
My antenna is the stock adhesive one that goes behind the factory radio antenna. It's pretty big. The tuner is the one that comes from the Toyota OEM kit. Not sure of the part number.
maximthegreat
Jan 19, 2016 02:31 PM
pjl52
Aug 13, 2015 02:38 PM
semlin
Jul 29, 2015 02:07 AM
Azsundevil
Jul 25, 2015 11:10 PM
Bish80
Jul 24, 2015 02:02 AM
