View Full Version : what type of lugs are appropriate for steelies?
ryuji16
07-08-2008, 08:40 PM
ive been reading up a bit on lug nut options, and learned that there are some tuner lug nuts that wont work for stock steelies. i have tuner lugs on my current rims right now, but im afraid to use them on my steelies because im not sure if theyre appropriate — they are mcgard spline drive lugs.
im going to be riding my steelies for a while so i want something thats lighter and more decent looking than the stock lugs. i was looking into muteki closed ended lugs, because they come in red and arent as expensive as rays or anything like that (besides, why would i put lugs that are worth more than the wheels, right), but i dont know if those will work because it looks like those are also tuner lugs.
for those with dressed-up steelies, what kind of lugs are you running? so far ive been seeing mostly chrome lugs, but are those a specific type that is different from the tuner lugs that mcgard and muteki make?
burstaneurysm
07-08-2008, 09:27 PM
As long as it has the conical seat, you'll be fine.
Edit: Here's the pic I was looking for.
http://www.tirerack.com/images/wheels/tech/lug_nut.jpg
ryuji16
07-08-2008, 09:30 PM
ok, looks like the mcgard lugs i have will work. looks like it also means that muteki will work too. thanks, that pic really helps
ryuji16
07-08-2008, 10:14 PM
see, heres what confuses me, the disclaimer near the bottom of this page:
http://www.evasivemotorsports.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=WORK-RSLUG-RED&Category_Code=L1&Store_Code=EM
it says these are not made for oem wheels. they make it seem like they will get damaged or something
burstaneurysm
07-08-2008, 10:35 PM
If you compared the seat on the stock lugs with the seat on the aftermarket, they'll be the same.
I had gorillas on my steelies for a while and my splines will fit too...
Basically, that disclaimer is there since not all stock wheels have a cone seat.
Hondas, for instance tend to have a ball seat, some wheels use the flat seat.
In these instances, the lugs aren't going to work since they won't seat properly.
However, since the xB uses a conical seat anyway, it's fine.
ryuji16
07-08-2008, 10:43 PM
cool, i guess that settles it. thanks
bB2NER
07-25-2008, 03:35 PM
Pretty much and 45 degree tapper lug will work with the steelies. I've run several diffrent chrome tuner lugs with mine with zero issues.
ryuji16
07-25-2008, 04:25 PM
ah, ic. i just saw that there are also 60 degree tapered ones, and i was just about to ask that question. cool
turbotim
08-01-2008, 12:13 AM
What he ^ said
