Cut or No Cut - Front Strut Rubber Bumpers
I'm planning on installing Tanabe NF210 springs (1.0"F / 1.7"R drop) with TSW 18" staggered wheels / Tires:
Front: 18x8.0 +40 225/40-18
Rear: 18x9.5 +40 255/35-18
Would you recommend cutting the rubber bumpers on the front struts???
From what I understand, cutting these bumpers gives your struts that much more suspension travel. I would think that this would equal to a smoother ride and less chance of bottoming out the front suspension.
I've seen people cut the bumpers in half with the Tanabe DF210 (1.7"F / 2.1"R drop). Since the NF210 is a relatively mild drop, I was thinking of cutting off just 1/4 of the bumper. Anybody have any rubbing or bottoming out issues with 1/4 cut off.
Would leaving the whole bumper uncut help alleviate any potential rubbing issues?
I'm just very worried that I'll have rubbing issues when fully loaded with people and hitting speed bumps or pot holes.
I also noticed the TRD spring install instruction do not mention anything about cutting these spring bumpers.
Thank you for your response and recommendations.
This should put your mind at ease:
https://www.scionlife.com/forums/vie....php?p=3385299
19-8.5 +35 Offset Front w/235-35-19 General Exclaim
19-9.5 +45 Offset Rear w/265-30-19 General Exclaim
The strut bumpers have 3 nubs (it'll make sense when you see them). I was the first to put NF's on, and my spring installer cut off the 1st nub (smaller end) to match the 1" drop. My understanding since then is that nobody else with the NF springs has cut their bumpers, and none of them have had any problems at all. The front drop is the same as TRD, so I say leave them alone and don't cut them.
I have had my NF-210's on for about 1,500 miles so fair and love them. When installed i did not Cut the Bump-Stop's they were left alone. I have not had any problem's what so ever, Going to be adding 18" wheels soon alonge with Tanabe Strut Bar and Tanabe Under Brace and a Rear Sway Bar.
Thank you again CIONIDE
If it doesn't say to do it in the directions then don't do it. When I put my tein H-techs on my tC it said to cut a certain amount. If you end up bottoming out all the time then maybe you could cut a little but I don't think you will have a problem. And if your tires rub they're probably going to be on the fender lip because you're rears might have the wrong offset. Tire rubbage would be caused by wheel and tire setup not drop.
The first nub will be lopped off!!!
CIONIDE,
I sincerely appreciate your great facts and encouragements on all your other posts. You've been a big help for sure.
I can't wait till I get it all together. I just want to do things the correct way the first time. I try to do as much research and fact finding as I can first. I usually sleep on ideas for a week or so before I go all out. I've got a bunch of parts (CAI, Exhaust, misc interior parts, alarm) ready to go in. I just need a buddy to help me out on a few of the installs..... That reminds me... I gotta stock up on some beer and soda.
I'll post pics in a couple of weeks of the box. I'll try and do some DIY info as I go along with some of the installs to help others out.
Thanks
CIONIDE,
Thanks
Team No Limitz
You should have no rubbing issues with +40 offset. I am running +38 and have some rubbing in the rear, but only if I hit a solid bump. I know +2 does not sound like a big difference but it can be either rubbing or not.
As for the nubs. I can not say on this one as to wether or not cut them. But when I did the S techs on my tC before I did the K sport coilovers, I cut them in half. Still had good ride, but kept it from ruining the struts.
NoLimitz, in addition to the 2mm difference in offset, he's also only going to be dropped 1.7" in the rear on NF210's, not the 2-1/2" to 3" like your rear coilovers. No rubbing at all!
evolving_machine
Oct 21, 2023 01:16 PM
anarvan
Oct 31, 2003 01:14 PM
