MY CAR WONT START!!!! HELP ME PLEASE
Old Jul 18, 2008 | 07:41 PM
mdaaboul313's Avatar
Default MY CAR WONT START!!!! HELP ME PLEASE
i was installing my neon lights inside my car and one of the wires grounded and sparked. now My windows wont work, my moon roof wont work, my radio doesnt work, my car wont start. BUT everything else works....WHAT DO I DO??? i checked my fuses and now im lost any one that can help i really appreciate it.
Old Jul 18, 2008 | 07:46 PM
locondcoco's Avatar
double check your battery connections. happened to me once. make sure its tight.
Old Jul 18, 2008 | 07:48 PM
it is....part of my car works and part of it doesnt
my power locks also DO work
Old Jul 18, 2008 | 08:21 PM
datdude1119's Avatar
what happens when u turn the key, maybe recheck the ignition fuse and all of that
Old Jul 18, 2008 | 08:23 PM
a_german_named_hans's Avatar
you checked both the fuses on the inside of the car and on under the hood?
Old Jul 18, 2008 | 08:29 PM
ok well this is what happens when i turn my key....all my dash lights turn on and my gauge needles still jump...
Old Jul 18, 2008 | 08:39 PM
CDogbert's Avatar
It's either the fuses or the alternator, methinks.
Old Jul 18, 2008 | 08:40 PM
kiss_kiss_kill's Avatar
Where'd it spark from?
wait. what did you wire up the neons up to? You should have wired them up directly to the battery.
Old Jul 18, 2008 | 09:17 PM
i did it through a fuse like the forums on oznium said to...through the cig. lighter...it just hit a piece of metal under the dash
Old Jul 18, 2008 | 10:45 PM
paulky_2000's Avatar
If you grounded a live wire and it sparked.....you have a blown fuse. Keep looking....you'll find it.
Why were you doing electrical work with the battery hooked-up anyway?
Old Jul 18, 2008 | 11:09 PM
Astoria's Avatar
read your manual? theres something in there about windows not working/car not starting. you have to hold the key at a certain position or something
Old Jul 19, 2008 | 01:38 AM
cweckel2000's Avatar
Check the fuses under the hood. That happened to me once on a Corolla and it was the dome fuse. When that blew the clock / radio / interior lights / and some other things didn't work.
That doesn't explain why it doesn't start but that might help some of your other problems.
Old Jul 19, 2008 | 04:23 AM
ok thanks for yalls help guys it was my starting system fuse?? but now my car starts and my sunroof STILL WONT OPEN, my speedometer WONT WORK, my abs, brake, and TPMS light is ON and my cruise control WONT WORK...now that me and 3 other people checked and rechecked my fuses, WHAT DO I DO??????
Old Jul 19, 2008 | 03:03 PM
Kvizzel's Avatar
reset your sunroof.
no idea about the others.
Old Jul 19, 2008 | 03:16 PM
DTC08's Avatar
disconnect the battery from the car completly then plug it back in.. may reset your system lights...
Old Jul 19, 2008 | 03:39 PM
Kanchi's Avatar
^x2 there is a reset process for the sunroof, if that dosen't work you still have blown fuses, get a tester.
Old Jul 19, 2008 | 04:05 PM
DTC08's Avatar
i remember my BMW had a blown fuse, radio, speedo, clock and a few other htings didnt work... pull each fuse and inspect it carefully that is most likely the issue.... ur lucky ur not dealing with an audi cuz those are worse to work out the electrical kinks
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
BV19869
Dec 11, 2014 06:05 PM
tC_Normo
Oct 22, 2003 07:20 PM
