ayS
12-10-2004, 05:58 PM
how do you guys determine what offsets are needed for rims for our cars, when thinking about purchasing some?
View Full Version : offset question ayS 12-10-2004, 05:58 PM how do you guys determine what offsets are needed for rims for our cars, when thinking about purchasing some? DJ_X_Trodinaire 12-10-2004, 06:08 PM please reffer to this link most of the listed wheel size offset are from members who have tried it. http://www.scionlife.com/forums/viewtopic.php?t=348 ayS 12-10-2004, 07:22 PM thanks dj! does anyone know if the offset will have anything to do with how much of a drop i want? another words, if i lower so low or so high do i need to change the offset accordingly? or if i do i just need to get the "correct" offset for a wheel to make sure it doesn't curve in and out, and that lowering your car has nothing to do with it? :roll: DJ_X_Trodinaire 12-10-2004, 07:49 PM if you keep within the 1 -2 inch lowering springs your offset should be fine this one is a common wheel set up 17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 ayS 12-10-2004, 08:14 PM if you keep within the 1 -2 inch lowering springs your offset should be fine this one is a common wheel set up 17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 okay cool, thanks for the info. im planning on doing a 8.0 width would that be a problem you think? Sid_xBicious 12-10-2004, 10:22 PM if you keep within the 1 -2 inch lowering springs your offset should be fine this one is a common wheel set up 17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 okay cool, thanks for the info. im planning on doing a 8.0 width would that be a problem you think? go to this site http://toy4two.home.mindspring.com/offset.html input your original spec input your new spec then physically determine if you have enough space in/out turtles808 12-11-2004, 06:07 PM This site may help. :arrow: Click (http://gs.tolan-hoechst.com/tirecalc.htm) |
