View Full Version : Broken lug nut? Need HELP!!!
xkillah
07-30-2008, 05:17 PM
Early this morning i got the lug nuts i bought online, as i was putting them on, wheel freaking nut just broke, i think i forced it too much.. :rofl:
so wheel nut split in half, the top came off so there's nothing to grab onto with a wrench. The bottom half is still on the stud holding the wheel on. is there a way to take it off? :nails:
HomelessGuy
07-30-2008, 05:20 PM
do you have a picture f the damage? did you try hammering on a socket thats 1 size smaller than the nut?
IcetC
07-30-2008, 05:30 PM
do what the homeless guy said to do just be careful when you do it because u don't want to mess up any of the threads or anything so just tap it down until its stuck and then take it off like normal but do it slow cuz u can mess something up if done wrong
xkillah
07-30-2008, 05:43 PM
i havent try anything, coz im afriad i might damage something in there and i just recently got the rims. but i tried sticking the socket i have but it wont hold the broken nut(mm left off the nut), coz the sucket is hitting the wheel.. ill try to post pics off this damage. today
xkillah
07-30-2008, 05:55 PM
here are some pics.
http://i34.photobucket.com/albums/d149/ricky0807/IMG00045.jpg
http://i34.photobucket.com/albums/d149/ricky0807/IMG00044.jpg
CarbonXe
07-30-2008, 05:57 PM
nvm.
CarbonXe
07-30-2008, 05:58 PM
What kind of lugs are those?
If you were properly using a torque wrench to put the lugs on when it broke, I highly suggest removing all the lugs and replacing with the stock ones.
Diluvium
07-30-2008, 09:20 PM
your screwed!!!!!! yes, i had the same issue with my enkei's when i took it off but thats because i forgot to put Anti-Seize Lubricant on it.
you can chisel if you have the tool to reshape into a socket. but i had to take my car to the autoshop and they had to drill the whole bolt and stud off. you have to buy new lug studs, they are pretty cheap. but the service will cost you. and its not a DIY thing you do need a air compressed torque gun to install the stud back on.
if you got some other cheap way to get it off just be careful not to damage the threads on the studs...
also when you tighten lug nuts by hand, you only tighten enough untill the whole car budges. meaning use your body weight to tighten closes then pull the bar and see if the whole car pulls along. thats TIGHT ENOUGH!
If you want to know when your lug nuts are loose, while your driving your gonna hear "cluncking" sounds as if each thump is heard per wheel full rotation.
Diluvium
07-30-2008, 09:33 PM
urm the way they took off the stud and bolt was using a torch gun. melted that sucker off! if you do let the mechanics get a hold of it, beware your rim will be damaged by heat regardless, unless you dont want it fixed at all...
when they install the new studs they use a stud socket and drill that stud into the rotor. the rotor part has teeth that eats the stud into itself. good luck
CarbonXe
07-30-2008, 09:35 PM
The only way to put on lug nuts is with a calibrated torque wrench. Any other way is wrong.
Diluvium
07-30-2008, 09:38 PM
well that leads no choice but to torch the sucker off!
Diluvium
07-30-2008, 09:41 PM
either way chiselliing or torching its gonna damage the studs regardless. not only replacing the studs but your rim is gonna sacrifice to get that bolt off....
Zsanz
07-30-2008, 09:50 PM
weld a nut onto the end of the broken socket and repeat.
a_german_named_hans
owned. This might not work, but i'd try and dremel the bolt from one side across it as deep as u can go. Then try and stick something metalic thats thin like a chisel or something and maybe split the bolt further down if possible. I'm not sure how that would work out for ya tho.
^^ that would work too.
Diluvium
07-30-2008, 09:56 PM
they do sell lug nut removers, im not sure how it works. i had a mechanic/friend explain to me there is a socket that removes broken lugs. the socket itself has teeth in it, all you do is apply force or torque gun it so the teeth in the socket eat through the nut and stays in place.
the issue is, as i see, your rim and the broken lug looks cramped up so i think it wont fit anyways...
Diluvium
07-30-2008, 10:01 PM
i doubt that too, first your gonna mess up your rims, second you might weld the lug and stud together..
3 look how compact the space between the rim and lug... i dont think you can fit anything between there.
CarbonXe
07-30-2008, 10:02 PM
It's not like they're good rims. They're sport max...
HomelessGuy
07-31-2008, 01:06 AM
oh man, that sucks, you will probly hae to get the stud drilled out, i would imagine that would be the only way to go about it and still save your rim.
tkevin07
07-31-2008, 06:52 AM
get the high end chisels at homedepot and start hammering that thing in and try to unscreww it while doing that, i hope u didnt torque it to the point where u need an impact gun
CDogbert
07-31-2008, 06:56 AM
Shut up, I have those exact same rims. :(
xkillah
07-31-2008, 04:42 PM
damnit.. just got back from work, so i guess i have to gather more inforemation not just in forums.
xkillah
07-31-2008, 04:43 PM
shut up men,. i got them for free so y not take em right?
ihavenosn
07-31-2008, 04:54 PM
Sooo what kind of lugs are those?
xkillah
07-31-2008, 04:57 PM
i bought em online JDM, but when i got em i start doubting them which i was right..
Diluvium
07-31-2008, 05:19 PM
well any aftermarket lug nuts are made out of soft metal (alum,titan, etc.), our stock ones are steel. after a while with aftermarket lugs removed and tighten back and forth the metal eventually bends. next time you just have to take those lug nuts lightly.
its more safer when lug nuts get "loose" because its easier notice with "clunking" noises and no damage is involve compare to over tightening that soft metal.... i weigh 145 so left hand on the angle of the lug nut tool and right hand at the end of the tool and just lean to the right is tight enough...
SengTC3
07-31-2008, 05:37 PM
Torque wrench + right torque specs = FTMFW!
Carlanga
07-31-2008, 05:48 PM
u could always take the other 4 off and drive around and see if it comes off :rofl:
xkillah
07-31-2008, 05:49 PM
i was using torque wrench, it just happen that i forgot i was working with aluminums. so pop! pop! pop! is all i heard. so learn from my mistakes.. =)
Carlanga
07-31-2008, 05:51 PM
no but seriously, it looks like u still have some sides left. Hammer a socket in there and torch that sucker, it should come off.
DonNguyen
07-31-2008, 05:54 PM
this is the reason people buy expensive lug nuts
Carlanga
07-31-2008, 05:56 PM
^ amen
SengTC3
07-31-2008, 06:11 PM
well on the positive note... You got 1 wheel lock, so no need to worry about that rim being jacked.
Carlanga
07-31-2008, 06:14 PM
^lol
xkillah
07-31-2008, 06:26 PM
lol^ tru taht!.. but yea dude, im still thinking and getting more info on how to get taht b!tch out!
xkillah
07-31-2008, 06:27 PM
i agree!.. guess where all learning.. from this crap
DonNguyen
07-31-2008, 06:29 PM
and the learning continues.
your statement should read
"I agree! I guess WE'RE all learning from this crap"
xkillah
07-31-2008, 06:30 PM
lol,, my bad..
ricexizxgood
07-31-2008, 11:42 PM
I was just at Sears today and they have this socket that is for taking off damaged lug nuts. You could give that a try.
CDogbert
08-01-2008, 12:44 AM
What a hilariously awful idea.
DonNguyen
08-01-2008, 12:59 AM
so you think
http://www.youtube.com/watch?v=xn11s1SmAPY
ricexizxgood
08-01-2008, 01:16 AM
so you think
Haha! It worked! I wouldn't try it tho hehe
jackotamo
08-01-2008, 02:12 PM
Yeah dont buy "JDM" stuff from ebay. They are usually cheap and crappy quality.
ihavenosn
08-01-2008, 02:32 PM
Wow those guys in the video was brave for even trying that.
xkillah
08-03-2008, 06:49 AM
finally i got it fix! geez taht was ____ing brutal..
DonNguyen
08-03-2008, 04:34 PM
how'd you fix it?
and go buy some good lugs...
xkillah
08-03-2008, 11:03 PM
i dremel to make a smaller enough to fit a smaller socket and tahts it.. its out! it took me like 6hrs to make a good shape..
xkillah
08-03-2008, 11:05 PM
how'd you fix it?
havent bought any lugs yet, still using the stock ones.. still traumatize on that crap.. :silly: any idea of a better lugs?
ricexizxgood
08-03-2008, 11:07 PM
how'd you fix it?
How much you looking to spend?
xkillah
08-03-2008, 11:44 PM
as long as they dont break like the other ones i dont mind..
ricexizxgood
08-03-2008, 11:50 PM
Hmm you could look the the Rays ones which are in the $100 range or Project Kics ones which range from about $150 to $250.
xkillah
08-04-2008, 12:05 AM
cool.. thanks men
