Megan drift spec studs
Old Aug 2, 2008 | 01:12 AM
GTS-T's Avatar
Default Megan drift spec studs
I purchased a used Megan exhaust and the seller had to rip apart the rear studs that connect the mid-pipe to the cat-back in order to remove the exhaust from his tC.
My question is: Where can I buy replacement studs? I've tried Ace Hardware, Advance Autoparts, Pepboys, and Northern Tools but those stores don't carry the length that I need.
Can my stock studs (bolts) on my axel-back work?
I've also called Megan Racing but they don't have any in stock..
Old Aug 2, 2008 | 01:56 AM
Kanchi's Avatar
^stock ones should work until you can get new ones...
Old Aug 2, 2008 | 03:51 AM
highvoltage1's Avatar
dang that sucks. Stock or hit up lowes or home depot.
Old Aug 2, 2008 | 04:33 AM
nlataille18's Avatar
i'm pretty sure just a regular spring bolt would due. as long as you got one with a nut on one end you should be fine.
Old Aug 2, 2008 | 11:40 AM
GTS-T's Avatar
I tried to look under my car @ the axel back but I can't tell if it's a bolt on. Anyone know?
Will the stock studs hold?
Old Aug 2, 2008 | 01:43 PM
what you trying to do know? Mount an aftermarket axelback?
Old Aug 2, 2008 | 04:23 PM
GTS-T's Avatar
It's the cat-back but, since the stock is an axel-back, I don't know what other studs I would use. Know what I mean?
I suppose if there's any studs on the stock exhaust system then I can just use them as temps for my Megan.
I'm actually tried to avoid having to take off the stock exhuast only to find out that I can't use the stock studs/bolts.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
rvascion
Nov 12, 2020 03:23 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mike_xb2
Scion xB 2nd-Gen Wheel & Tire
Sep 10, 2015 01:18 AM
