Need Help
Old Aug 2, 2008 | 12:00 PM
2006bluetc's Avatar
Default Need Help
I have the dezod S1 turbo kit for my 06 tc and I was installing the kit and got everything hooked up and bolted up. My problem is when I go to start my car it will take a few cranks to start then it idles really ruff and shuts off ....If I play with the gas pedal it will try to stay running but then it shuts off...and also when I try to rev it to keep it running it will sometimes drop to about 500 rpm then shoot way up to 2500 rpm then eventually shut off again....any help would be great because my car is in pieces right now
Old Aug 2, 2008 | 12:30 PM
paulky_2000's Avatar
Could be many things. I'd check to see you have the MAF sensor hooked in correctly first. Check for vacuum leaks. Did you reconnect the O2 sensor(s)? If you were messing with the fuel rail, did you reconnect the sensor plug on the left?
Disconnect the battery and go hunting for those things. There will be people on in a bit better versed in turbo setups. I'm kinda new at this myself
Good luck!
Old Aug 2, 2008 | 01:49 PM
B_Real45's Avatar
Definitely check your vacuum lines and MAF.
Old Aug 2, 2008 | 08:13 PM
Ace83's Avatar
Ronin Scion
what management? it could be tune related, some basemaps just dont work on some.. but yeah check what they said above
Old Aug 2, 2008 | 08:15 PM
Ace83's Avatar
Ronin Scion
or try starting with the maf sensor disconnected, it will run super rich but you will know if its vac/boost leak or tune related
Old Aug 2, 2008 | 08:18 PM
shoopajae's Avatar
check your throttle body. i dont have turbo but something similar happened to me cause my throttle body was stuck open.
Old Aug 2, 2008 | 09:16 PM
2006bluetc's Avatar
Ok here is an update... I have all the vac leak fixed but now my plug and play injectors won't seal properly.. I've used the oem o rings but I am still getting a big full leak. any ideas?
Old Aug 2, 2008 | 09:43 PM
B_Real45's Avatar
any pics? Are the rings sitting on the injector correctly? Maybe the injectors weren't pushed in correctly and messed up the rings?
Old Aug 3, 2008 | 03:27 AM
paul_dezod's Avatar
Scionetics
KAD
Did you use the lube that came with the injectors and seat them properly back into the rail and head?
Old Aug 3, 2008 | 03:38 AM
2006bluetc's Avatar
Well I bought the kit used so I didn't have the lube so I rubbed the o rings with a little gas. I like I just had a bad o ring, but everything is fine now as far as the car running. but I will take a picture of the injectors and fuel rail tomorrow so you can take a look to see if it's right
Old Aug 3, 2008 | 01:12 PM
Ace83's Avatar
Ronin Scion
so the car is working good now? just be careful with injector leaks, it could be dangerous
Old Aug 6, 2008 | 10:59 PM
2006bluetc's Avatar
Ok I took some pictures of the fuel rail and I will have them posted later tonight, but I was also wondering if anyone had problems getting the fuel injectors to clip back into the clips. my injectors seem to be getting caught on the orange rubber gasket that is in the clip....any ideas how to fix this
Old Aug 6, 2008 | 11:01 PM
java09's Avatar
you just have to wiggle it gently in there.. mine took forever but a good seal on those is a must!
Old Aug 7, 2008 | 04:40 AM
2006bluetc's Avatar
here's a pic on one of my fuel injectors....it's not leaking but this can't be right can it?
Old Aug 7, 2008 | 04:43 AM
JBGsTC's Avatar
That's definitely jacked Joe. You saw mine tonight, none of them have a gap like that, actually they don't have any gap at all. We just need to pull your rail and lay in on top of the engine and re-install the injectors, making sure they all seat before we put the rail back on, which they should because I got you those 4 new O-Rings yesterday...
Old Aug 7, 2008 | 04:48 AM
Ace83's Avatar
Ronin Scion
yup shouldnt sit like that, should be like the rest.. see whats keeping it from being pushed all the way
Old Aug 7, 2008 | 04:50 AM
2006bluetc's Avatar
well the thing is the fuel injector will move up and down in the fuel rail... so I guess hopefully it's an o ring
Old Aug 7, 2008 | 04:53 AM
Ace83's Avatar
Ronin Scion
^^ might be missing and o ring, all injectors should looks the same.. and you may get a leak from that one
Old Aug 7, 2008 | 04:55 AM
2006bluetc's Avatar
Yea I guess I'm just getting really paranoid because me and a few buddies did the install ourselves, but I'm sure it's an easy fix i guess
Old Aug 7, 2008 | 01:36 PM
paul_dezod's Avatar
Scionetics
KAD
The o-ring is probably not seated into the fuel rail. there is a little crevice in the rail inside the bung, where the injector sits to make a seal with the upper O-ring.
