Regional - Pacific Mid CA, NV
Custom Car Alarm Setup? Revised
Old Aug 2, 2008 | 04:55 PM
lasrx's Avatar
Default Custom Car Alarm Setup? Revised
Does anyone know of a custom car alarm installer that can provide the following customizations and/or provide me with an estimate.
1) Two way alarm.
2) Secondary battery installation /w Enough power to run the next item for up to 5 minutes.
3) Interior Siren Mount (110db+ preferred)
Update: Removed the voltage step-up requirement. There aren't any prefab kits for this so it's probably beyond reason. I think the rest of this should be reasonable.
Old Aug 3, 2008 | 04:35 AM
365Motorwerks's Avatar
Default Re: Custom Car Alarm Setup? Revised
1) Two way alarm.
You can get a second horn with a built in battery that will easily go 5+ I used to have one in another car that I mounted way up inside the dash and it would trigger with the main horn....____ed the dealer off when they disconnected the battery and the lack of power set off the horn the only way to disarm it was a key which they didn't have and they had to rip apart the dash to remove the horn! They said it was driving them nuts!
Old Aug 3, 2008 | 08:33 PM
lasrx's Avatar
Sounds exactly like what I would like to do. My main goal isn't to make it louder on the outside. Just much louder on the inside to disorient / cause hearing damage for the people trying to steal from the vehicle.
Old Aug 3, 2008 | 11:51 PM
Yep my idea exactly ...the other thing I wanted to add was strobes inside I figured then you wouldn't be able to see if it was at night! Just ask when you get the alarm done they will know all about the horn. I had one done at the shop on King / Alum Rock but it was so long ago I don't remember the cost, they did a good job though.
Old Aug 13, 2008 | 05:36 PM
moneymike's Avatar
Custom Car Alarms in Concord off of Contra Costa Blvd. can take care of all of this for you. I've brought my car there and made my alarm purchase from them which was a two way system from Clifford Matrix. I highly reccomend you go in and talk with them, or give them a call.
scionlife
May 4, 2017 07:13 AM
CONCRETETC
Feb 9, 2015 08:05 PM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
BV19869
Dec 11, 2014 06:05 PM
tC_Normo
Oct 22, 2003 07:20 PM
