Fog light relay vs Toyota relay..
Is there any diff. between the fog light relay on Scion vs the Toyota relays. I know the colors are different.
I can't believe they want $50 for the Scion relay and that's with my emp. discount.
__________
__________
Originally Posted by too boxy
Is there any diff. between the fog light relay on scion vs the toyota relays. I know the colors are different. I can't believe they want $50 for the scion relay and that's with my emp. discount.
ok so i picked up a generic 30amp relay n wired it for my aftermarket fogs.
Here is the wiring order:
Harness color_______________ Relay Pins
Red w/white stripe _______________ #87
Green w/orange stripe ____________#86
Green w/red stripe________________#85
Double Green w/red stripe_________#30
ill snap a picture tomorrow of the harness i made to adapt an aftermarket relay so you get a better idea
i have not checked my fog light relay yet....
but the toyota relays are a unique design 4 pins only, and are small rectangles....
completely diff than the generic 30 amp relay....
hence the harness that i had to make to adapt it to work
a standard 30 amp relay is 4 pin also
as seen here:
http://www.ado13.com/techs/relay.htm
i just had to figure out what wire did what in the factory harness plug
as seen here:
those .99 cent relays also have an 87a (most of the time)
the toyota one i know has a different base and pin design.
still, i don't know what relay my box uses for the fog lights....
yeah, i had to figure out the wires too.
i was putting in the air horns, and it stuck....(that was loud and annoying...)
i thought i was pulling too much current an welded the contacts...
turned out it was a bad relay....
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
TheTripleC
Jan 4, 2015 06:46 PM
