Need Pictures of parts spread before install
If someone has a Turbo Toyotas Standard Stage III kit or one of their kits that are equal in parts to this kit, I need to see pictures of what it included so I can email my parents to see if the kit has everything in it. I need pictures before install with the parts laid out. Thanks.
I need pictures of the parts laying on the floor or something. The main thing I am concerned with is seeing the IC pipes off of the car, hoses, clamps, fittings, and vacuum block.
i think there are a total of...
4 pipes cold and hot
you got...one that should be crooked going around the metal thing under the engine bay from the intercooler and one going to the turbo.
the cold side shoudl have one with a BOV fitting that connects to another that bends in somehting that looks like a 90 degree angle.
then the intake pipe.
so 5 pipes. you should have....four clamps for the hot side
5-6 for the cold side
fittings you should be fine. if you don't have the vac block you would also be fine but you should recognize it.
That helps a little but the problem is my parents are the ones that will look at this for me and don't know much about cars. If I had pictures I could email them I would know if the kit was complete or not.
I have some pics on my thread too, its not a stage 3 but you wouldnt notice much lol
https://www.scionlife.com/forums/vie...ht=texas+style
mine has
2.5" downpipe/s pipe
38 mm wg
gt3076 turbo
smaller Intercooler
and prolly thats the only difference unless you got the twin scroll
mine has
38 mm wg
gt3076 turbo
smaller Intercooler
Originally Posted by toyota_scion_tc
Thanks. BTW who is Cory James?
thread is locked but not deleted:
https://www.scionlife.com/forums/vie...084&highlight=
If you read through the whole thread (
) you will find a parts list that might help!
lets see...there is on intake pipe, on hot side IC pipe that bends down sharp, the cold side that matched that bend on the other side, then the top IC pip with the BOV flange on it...that should be 6 couplers with those...those pipes are all aluminum...then there is the manifold, downpipe and s pipe that are all steel.
