unable too pull or add timing on emanage ult
Old Aug 3, 2008 | 11:41 PM
cmcpride's Avatar
Default unable too pull or add timing on emanage ult. but at 325hp and climbing
i took my scion tc over too church's for a tune, i was told that they couldnt pull or add timing to add more power, no change in timing . i was only able to get 201hp and 185t without adjusting timing ,on a auto tc supercharge with emanage ult , has any one ever had problems with timing , i was told if i get info in how to adjust timing i could get more power....
Old Aug 4, 2008 | 05:02 AM
toyota_scion_tc's Avatar
Keep in mind the Emange can only do so much at partial throttle due to the OEM having control. At WOT the Emange will have full control, check the settings or wiring. I know when I had my Ultimate plugged up the tuner had control over the timing.
Old Aug 4, 2008 | 05:05 AM
unxpectederror's Avatar
yeah just sounds like you ether don't have it wired right or you have a lame tuner
Old Aug 5, 2008 | 02:22 AM
cmcpride's Avatar
im running a pnp harness from dezod, i wanted to make sure installation was good , no mistakes. tuner ? they didnt even know how to set jumper setting correctly.. i went on line too the city of scionlife for info for my self .thanks scion dudes. and im also hopeing to resolve my timing issue.
Old Aug 9, 2008 | 05:05 AM
cmcpride's Avatar
Default running too rich
if im able to run on regular fuel none prem, with no problems does that mean im running too rich? no knocking or pinging it even runs better
Old Aug 9, 2008 | 05:24 AM
Best thing to do is to get it dyno tuned with a wideband in your s-pipe, assuming you don't have the OEM header with the cat in it. That way you will know what you AFR is and I would run premium you can get more timing advance and not have to worry about predetonation as much. Any experienced tuner should be able to safely tune your car to see what’s best for it.
Old Aug 9, 2008 | 05:38 AM
equinox2355's Avatar
Default Re: running too rich
under forced induction, you should NEVER run anything UNDER the fuel needed and I haven't seen any forced induction vehicle use any less than Premium (91-93) if you are running that, you would be asking for trouble, even with a tune!
Old Aug 9, 2008 | 07:48 AM
cmcpride's Avatar
Default running rich
how much more hp should I get if i retune , im at 201hp and 185t auto tc with shift kit supercharger , emanage ult
Old Aug 9, 2008 | 02:30 PM
B_Real45's Avatar
No one but your tuner can answer that.. and that's after he does it.
Old Dec 25, 2009 | 07:46 PM
ESEMRFOZZ13's Avatar
any update?
Old Dec 26, 2009 | 12:06 AM
TheLowDown's Avatar
It might be safe to run 87 on your sc scion BUT the stock comp is pulling allot of timing......run higher octane and the computer wont hold the timing anymore. This maybe why the tuner didn’t want to advance your timing....
Old Dec 27, 2009 | 06:28 AM
gingles's Avatar
wideband in the s-pipe is ok......as long as its before the secondary o2 sensor and doesnt block the air path to the second o2 sensor.
also.....premium gas is pretty much a must with FI. reason being as it reduces the chance of knock more then regular....you can run regular but its alot easier to achieve detonation, therefore us FI guys just pony up the extra couple cents per gallon and have that added security
as far as them not being able to pull/add timing, make sure the jumpers are correct(double check them) and make sure the settings in the emanage are correct.
Old Dec 27, 2009 | 06:13 PM
myr6goesfast's Avatar
Who worked on your car at church?
Old Dec 27, 2009 | 08:08 PM
racer115's Avatar
you should be running alot more hp than that i just got mine tuned im running emanage blue tho with supercharger and im auto also we pulled timing to it and that made 240 on the dyno so i would say your tuner is not that good
Old Dec 29, 2009 | 12:02 AM
thendawg's Avatar
Are you tuning with the ultimate on top of the TRD flash? I know the TRD flash pulls quite a bit of timing so advancing it with the Ultimate could def give you a decent gain - Id go to another tuner as Ive never heard of anyone having issues with timing advance/retard on the ultimate.
Old Dec 29, 2009 | 01:47 AM
cmcpride's Avatar
shawn performed my tune, i just upgraded to a 12psi pulley and installed intercooler port and polished head with b/c stage 2 cams and im at 325hp. but still haveing problems with knocking..
Old Dec 29, 2009 | 03:08 PM
thendawg's Avatar
What afr are you seeing under boost? If you knock you have a couple options - adding fuel will help to a certain degree, pull timing (the best option), or use higher octane fuel.
Old Dec 30, 2009 | 10:24 AM
FREEradical's Avatar
LOL this doesn't even make sense. This guy wants to advance timing not retard it....sounds like someone retarded you! Haha jk, but seriously the blue can't add timing. Additional timing is what makes power, pulling timing loses power. Sounds like the dyno you ran on is bogus, 240 on auto supercharged with emanage blue pulling timing on top of the TRD reflash pulling timing = not really 240. But I digress. Hey to the op I think the problem is that the TRD reflash is just fighting the emanage, others have had the same problem. Was he unable to adjust timing at all or he just said it wasn't successful? Unichip is the only piggyback i'm aware of that's been really successfull advancing timing on the TRD reflash.
Old Dec 30, 2009 | 10:25 AM
Bro....pics or it's untrue. 325 whp on the supercharger is a new record. Make it official.
Old Jan 1, 2010 | 04:32 AM
cmcpride's Avatar
Default dyno s/c at 325hp and climbing
ok. ^^^ this was after adjustment and before i installed my water to air intercooler. at one point i hit 345hp but started to knock , i just might need to go with a three step colder spark plug . what do you guy think>> Name:  scan0001.jpg
