View Full Version : Shut the door w/ window down. Sounds like crap!
tcm_xB
12-13-2004, 01:44 AM
When I had my car serviced for a few TSB's the drivers window was rolled all the way down. I got in the car and closed the door. Ratttttttlllllllllllleeeee...... I don't know if it's my xB or all, but the door and it's componets rattle like hell. Sounds real cheap....
That same day the dealer gave me rides to and from the house while my Box was worked on. Rode in a new Highlander. Man, could you tell the difference between the xB and Highlander. I know that the Highlander is about twice the price of the xB.
Has anyone done anything to make the interior quieter with various rattles or quieter on the highway (noise wise)?
Anyhow shut your door with the window down and let me know how it sounds.
Thanks!!
oneslowxa
12-13-2004, 02:10 AM
when my window is cracked about 3 inches it rattles when i drive... and sounds scary when i shut the door as well... they say the window track/mechaincs is similar to the design of the tacoma
chadfo
12-13-2004, 03:07 AM
Mine has made some noise but some sound dampening in the doors will make a ton of difference. I did my front but haven't had time to do the back and the difference is night and day. Find some Dynamat or similar stuff and that should help. If the noise is very bad, you might want to check the hardware to make sure nothing is loose.
UnFocused
12-13-2004, 03:26 AM
sorry to break it to you, but every car on the planet will rattle when you shut the door w/ the window down....My Focus sounds twice as bad!
SWF_05_tC
12-13-2004, 05:26 AM
Not all cars will do that, I've had plenty that were solid as a rock.. believe it or not, my old tC was one of them. Anyway, my box does the same thing, sounds like the window is going to break. It's just cheaply made/put together is all, some sound dampening will make a world of difference.
Sublimize23
12-13-2004, 06:23 AM
14,000 dollar car....
Zombietime
12-13-2004, 08:19 AM
Sound dampening doesn't really make a difference if the window is down when you shut the door. I have two layers of good sound deadening on every door and it still does it.
srawls175
12-13-2004, 01:42 PM
Thicker windows and an extra 40K for an IS300 helps too.
WagenMaster
12-13-2004, 10:45 PM
How did you Dynamat your doors 'ChadFo'?
I was going to apply Dynamat Extreme on mine but didn't want to remove the sheet of plastic. I ended up using eDesign's v.3 liquid sound deadener and applied a whole gallon to the four door panels. I'm thinking of applying some more material to the actual doors too, so I'm curious how you did yours....
PS: My New Beetle's doors never rattled.
RPMxB
12-13-2004, 10:58 PM
... Has anyone done anything to make the interior quieter with various rattles or quieter on the highway (noise wise)?
Here's a 2 page thread from mid 2004 that discusses these issues:
The Doors
http://www.scionlife.com/forums/viewtopic.php?t=11168&highlight=doors+sound+tin%2A
:P :roll: :P RPM
grnxb
12-14-2004, 12:41 AM
if you want to sounddeaden the door, you've gotta remove the plastic. Don't worry, it's real easy to put back on.
I used b-quiet extreme. Pretty cheap and seems to work well. Went on real easy. Don't know what it sounds like when I close the door with the window down as my windows are usually up.
chadfo
12-14-2004, 01:11 AM
I put dampening sheets on the outside door skin and then some on several of the larger areas on the inside sheet. It's been a while since I did it so I don't remember every detail but I tried to put pieces anywhere that I thought would transmit noise either from vibration of driving or something moving about like wiring, etc. Just remember that you don't have to cover every square inch for the dampening to be effective. Testing has shown, no I don't have any specifics that I can share it's been too long, that covering a small area vs. covering the whole area resulted in little difference in the dampening characteristics.
The plastic is no problem to take off and put back on just don't let the black adhesive touch anything. Putting dampening on plastic stuff helps but metal vibrates and transmits more sound because it is thin, dense and flexible. Put most of your effort there. Unless the window or drive mechanism is actually striking something putting extra dampening on the inside door sheet will will reduce the noice.
rallyxb
12-14-2004, 02:04 AM
Not true... have you every shut the door in a Volvo S60 with the window open?
They don't make noise.
Because... they have lots of Dynamat inside the whole freekin' car!
:wink:
Check out all thier products here...
http://www.dynamat.com/
scionguy05
12-14-2004, 02:54 AM
when i had the stock sound system my componets rattle when i drove, was really getn to me,but when i went and got a after market sound system put in they put mynew componets were the stock ones were,and i havent heard a rattle since,
quadoptix
12-14-2004, 03:22 AM
hi, you own a scion..your welcome =P what u expect for a 15k car? civics hyundais and all cars in this range r like that..i mean yeah a benz dont do that but a car our price range will.
windowtint
12-14-2004, 03:35 AM
you should close the door on my Porsche a little to hard - the window sounds like it's going to explode when it slaps closed - 5x what the orange crate cost. - There are alot of cars that sound 'weak' when closing the door, regardless of cost.
2tone_xB
12-14-2004, 05:41 PM
Sounds the same like every car that has their window down...to me.
JACKNBX
12-18-2004, 01:40 AM
Just sell your car and get on with your life. You complained about your box since you got it. Buy your house and your hatch and go on down the road! :D
12-18-2004, 03:06 AM
:lol: dam, I guess so. I also have the rattle, but I never did it again. Its just like the old GM vehicles that had no rail at all and you lowered the window and closed the door. Over time the window came loose. So stop opening your windows 1/4 and just roll the dam thing all teh way down! :D
nest
12-18-2004, 09:48 PM
Not true.
Many older cars do, but these days it's limited to less expensive cars (or poorly built new cars)
My VW Jetta never did that with any window, always sounded like a bank vault when you shut the door.
That is one area where I have to agree though. The flimsy rattling, while common in cars in this price range, is a little disconcerting. I am planning on trying some of the dynomat myself when I get around to it. It's a minor nusaince but it seems like there should a simple, cost effective way to build car doors that don't do this. I expect it is more of a priority for Americans and Europeans. Japanese don't seem to mind a car door that weighs 12 oz. and don't immediately identify that with cheap quality.
Then again, they build house out of paper too.... :?
scion04xb
12-18-2004, 11:35 PM
mine sounds fine when i close it??? maybe u guys are slaming it i mean u dont have to push hard to close the door when the window is down :?
Kyle480
12-19-2004, 12:28 AM
you get what you pay for ;)
BrianxB
12-19-2004, 01:56 AM
My 02 Celica didnt do this, but my box does.
dgHotLava
12-19-2004, 02:40 AM
dynomat!!!!
SuperCrunchyAction
12-19-2004, 02:46 AM
dynomat!!!!
wow for the billionth time, dynamat does not prevent the window from rattling when it's lowered as the door closes.
12-19-2004, 08:40 AM
than take it back to the dealer and complain. Lets see what they do. Problem solved :)
