Super GURU needed for ? Naviagation Hack VSS wire rating
Originally Posted by equinox2355
well im not sure why you want to know the amperage, but you are aware that the signal that goes over the VSS wire is a pulse signal, right?
the reason is with the Navi hack, you use a switch to cut the signal in the vss wire.
the switch Ihave is a 3amp rated at 125VAC
I just did not what it to get hot.
do you know what kind of pulse it is.
I wouldn't be able to search right now, I am at work, but maybe when I get home (if I have time) I will try and search for you.
rancur3p1c
12-19-2014 04:30 PM
randode
44
06-29-2004 04:19 PM
