Decrease in power after CAI
Old Aug 10, 2008 | 08:43 PM
jcortes's Avatar
Default Decrease in power after CAI
I just installed my Injen cool air intake and there is a noticeable decrease in acceleration. I double checked everything and its all connected properly. Has anyone else experienced this problem?
Old Aug 10, 2008 | 08:46 PM
GhoZt's Avatar
Do you have any other mods installed?
Old Aug 10, 2008 | 08:48 PM
jcortes's Avatar
no just the Injen Cool Air Intake
Old Aug 10, 2008 | 08:49 PM
ScionDave's Avatar
im sure u just think there a problem... but u can disconnect ur battery for 15min and then let ur ECU reset and then see if theres anyother issues...
that what i had to do when i installed a MOPAR cold air intake on a '09 Challenger at work and then it felt right.
Old Aug 10, 2008 | 08:52 PM
jcortes's Avatar
I reset the ECU when I installed it. I can try again but there is a definite decrease. Sounds amazing though.
Old Aug 10, 2008 | 08:55 PM
ScionDave's Avatar
hmm... thats odd... hopefully u didnt have debris in the intake pipe... that might do something not so good.
Old Aug 10, 2008 | 09:05 PM
Scott8's Avatar
please explain the "decrease" you are noticing?
Old Aug 10, 2008 | 10:56 PM
tCtCtC's Avatar
x2 with scott
Old Aug 10, 2008 | 11:00 PM
jcortes's Avatar
Mainly when accelerating even when I floor it there isn't much response it barley picks up at all. If i have a rolling start and floor it though it kicks and revs up but from a stop i have to floor it constantly to get it to move basically.
Old Aug 10, 2008 | 11:01 PM
tCtCtC's Avatar
u sure this isnt in your head?
Scott8's Avatar
that sounds off.... you sure you have the couplers tight?
sounds like you are having a pressure leak that is cosing it to bog down
Old Aug 10, 2008 | 11:03 PM
jaxtcracer's Avatar
x2. maybe you expected the CAI to add a lot of hp, when in fact it really didnt. so you feel stock, which in turn makes it feel "slow"
Old Aug 10, 2008 | 11:13 PM
jcortes's Avatar
Im currently resetting the ECU because I had forgotten to connect the wires yesterday and drove with them disconnected I guess VSV does that sound right. Anyways after the first test drive I came back and connected them but never reset the ECU. Ill post back in a few when I test drive it.
Old Aug 10, 2008 | 11:24 PM
jcortes's Avatar
seems to be doing better thanks all.
Old Aug 10, 2008 | 11:26 PM
tCtCtC's Avatar
enjoy!
when you rev it at idle, can you here like a whistle sound?
Old Aug 10, 2008 | 11:29 PM
equinox2355's Avatar
Well from what I understand on a N/A tC with no other mods, an intake does not add any extra power or if it does its very little and only in the high RPMs
Old Aug 11, 2008 | 12:14 AM
jcortes's Avatar
enjoy!
It does whistle a bit when i press on the gas but it used to do that with the old intake as well.
Old Aug 11, 2008 | 12:20 AM
tCtCtC's Avatar
ooo ic ic.
im selling my turbo and getting just a intake... back when i had my fujita it just sounded louder with no whistle, so i hope this will be better
Old Aug 11, 2008 | 02:26 AM
engifineer's Avatar
It shouldnt get faster or slower. An intake on a tC is just going to look pretty and sound neat.
As far as a pressure leak as mentioned above, there is no pressure to leak. If you removed one coupler all together, all you would get is an intake with no filter on it. The engine is sucking air through the intake, there is no air being forced in.
RY_TC07
Jul 18, 2017 05:18 PM
Ravendarat
Jun 9, 2015 01:25 PM
hampton1100
May 28, 2015 07:32 AM
CrowJenkins
May 4, 2015 04:52 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
