you guys know how say they yeild an 8 hp increase, but doesnt the cai really help the most when driving at high speeds with all the cold air flowing into it , cause when its on the dyno no air is being forced into the cone
dgHotLava
12-14-2004, 12:42 AM
they should have a huge fan blowing air over the radiator / front end. (otherwise it could over heat...)
the hood should also be opened, to let heat rise away from the motor...
tckurt
12-14-2004, 12:43 AM
they put fans in front of the car most of the time to simulate the road... but I guess it could go up a very small fraction...
dgHotLava
12-14-2004, 12:53 AM
some people will argue that the fan is constant speed therefore not true road conditions... but i the world is not a perfect place...
hahaitzskippy
12-14-2004, 01:42 AM
some places i know actually have the fans connected to the computer so it will blow MORE air as the RPM's increase.
but most places dont...
smurf3642
12-14-2004, 12:10 PM
yes...very difficult to simulate "real" road conditions on an immobile Dyno...
especially on a true CAI system...
dgHotLava
12-14-2004, 12:50 PM
try doing it on a ram air set up....
where the wind does make a diff at speeds...
mfbenson
12-24-2004, 04:05 AM
That's why a dragstrip is the only real place to see if there is improvement or not. Of course, it requires a very consistent driver... one reason why the best e.t. bracket racers never have to look for work...
dgHotLava
12-24-2004, 04:47 AM
true....
but it also takes a lot longer to tune properly....
mfbenson
12-24-2004, 04:58 AM
Yup, takes all day if you have the track to yourself. All weekend if you don't. But its a tried and true "old school" method that these newfangled dyno's just can't quite reproduce.
Oops, I'm showing my age again...
dgHotLava
12-24-2004, 04:11 PM
how very true ^^^^^^
tCshamgar
12-24-2004, 07:06 PM
also, road temperatures are a bit different than air blown in by a fan. might take that into consideration
Hudnut
12-28-2004, 02:11 AM
I doubt that any cold air intake will provide a ram air effect.
dgHotLava
12-28-2004, 11:06 AM
probably not....
unless you build a ram air box around the filter
Stefan_TC
12-29-2004, 01:10 AM
Who said anything about blowing into the cone? :))))
The idea is that the air aroudn the fender is cold as opposed to air from the engine bay or behind the radioator........
The fans on the dyno are supposed to compensate for natural air flow through the radiotor so the engine does not overheat, nothing else........
dgHotLava
12-29-2004, 01:36 AM
right ^^^^^
cold air intake is not a ram air setup...
hotlava1096
01-05-2005, 01:08 PM
actually once you get moving there is less diference between a cai and a short ram. A cai makes the bigest difference when the car is stopped or a a low speed when little to no air is moving throught the engine bay. At this point the air in the engine bay is quite hot and the air the cai is sucking from the bumper is much cooler. Once the car is moving and the air is rushing through the engine bay the temperature difference becomes quite small(2-10 degrees or so depending on speed) and They perform about the same. So basically the dyno is a good represtentation of a situation where the car is at speed but is not the greatest representation of the difference that is pleasent when moving slow or taking off.
StraitR
01-05-2005, 02:01 PM
Nicely written lava. Makes good sense to me.
grnxb
01-05-2005, 02:19 PM
I remember a guy who posted a month or so ago...did a CAI, header, and something else...basically spent at least $800-$1200 or so and ended up with about 8hp extra.
I guess stating that you will get 8hp with just a CAI is a little optimistic.
91Mike
01-05-2005, 06:54 PM
There's not much difference between a CAI and a short ram period. A good intake should be a supporting modification, not a modification by itself. As long as it filters the air and is as unrestrictive as possible, it's serving its purpose. It will allow everything else to perform at its peak. If you're putting on an aftermarket intake system just for the few hp you'll get out of it, I hate to say it, but your car is probably not very fast.
Rivulent
01-05-2005, 10:54 PM
The point of a dyno is to have a baseline, all the same type of test where you can determine a car's power in a controlled enviroment.
Chimmy3
04-14-2005, 04:36 PM
I think the problem is ...
its extremely hard to control all the variables surrounding a dyno run, and even if you do, you might potentially end up with results which are not applicable in the real world.
For example, if I were to conduct a comparison of any power mods as scientifically as possible.. I'd have to be able to control all the factors...
so, the car would have to be computer driven, inside a regulated chamber, with humidity and abient temperature perfectly stable and controlled. In order for just a semi-complete analysis, a run would have be made for each product, and 3 runs per every variable that could change (complete analysis would require more runs and a run for every combination of variables resulting in possibly hundreds of runs per trial). There would have to be a few pre-trial runs just to get the engine up to a regular temperature. To account for the ECU, you'd probably have to reset it every time (if you don't just circumvent it outright) and simulate as best as possible, the standard learning curve for each intake. You should also run at least 5 trials per intake, and then discard the best and worst performance for each one and average the rest.
THEN, and only then would you maybe have something that you can use from a dyno to predict somewhat accurately how a single power mod will enhance performance.
Lacking those things... well then a dyno is basically as good as your best guess as to how something will perform (unless there are truly huge increases... in which case... well you wouldn't really need a dyno to tell you that)
