sleeving the block
hey guys ive got a problem, ive got my stock motor smoking from blow by so bad i cant drive the car anymore, but ive got some forged pistons, rod and main bearings, and a head gasket at home
im deciding should i build a new motor or buy a used one from a salvage yard. it will cost me 1200 for the used one
btw do i need to sleeve the block?
i plan on getting the k1 rods and arp main and head studs if i do this but my question is do i need to sleeve the block for the new pistons? if i do how much would this cost? thanks for the input
I would sleeve it if you're looking to run really high boost (20+) and over 400whp. It's not necessary - but if you're building a block from scratch, why not have that extra security.
Contact ERL for their sleeving services.
For your new pistons you don't really NEED to have it sleeved - you need to have it honed and bored to the spec's of the piston.
I would sleeve the block if i built it.. not really needed though if you just run med boost but as mentioned its for extra insurance since you are building a high stress machine.. important thing though is to find a reliable shop that can build it
Depends on how much you want your build to cost.
If you plan on upgrading your intake manifold, customizing the fuel rail, running a stand-alone, and some large turbo, then you should sleeve it.
If you're looking for 400whp reliably, then I would suggest that you buy a standalone EMS instead and just put in the pistons and rods. The stock sleeves are pretty stout.
So for like 350-400 hp, a simple piston and rod upgrade will do reliably? I already have a standalone to start with, as soon as I find a shop i can trust to do the build, i might go for it..
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
