Wheel Bearing Help Please
Old Aug 14, 2008 | 07:43 AM
airicwong's Avatar
Default Wheel Bearing Help Please
I just replaced my driver side front wheel bearing, at 65K miles. That's lame that it would go out so soon.
But my question is, should wheel bearings be replaced in pairs, like most suspension parts?
Thanks
Old Aug 14, 2008 | 12:50 PM
Improbcat's Avatar
Unless you are getting signs the other bearing is going out, don't worry about it. The sealed units the xB use generally only fail at that kind of mileage if they get dirt/water in them or there is a defect.
Old Aug 22, 2008 | 11:12 PM
Guest
Guest
Posts: n/a
You are not the only one who has had it replaced. We had a customer come in with about that many miles and replaced both of them. You do not need to do both either, just the one that is bad. We also had to replace the one on the rear for another customer, but that was because they curbed their wheel and when doing so messed up the bearing in the process.
bEWARE THE rear bearing assembly is dealer item only and is in the $350 range for the part alone.
Old Aug 23, 2008 | 09:51 AM
airicwong's Avatar
thanks guys...replacing the wheel bearing made the world of difference...it was so loud before and I thought it was tire noise, but now you can hear a pin drop...lol
Old Aug 26, 2008 | 05:15 AM
bmph8ter's Avatar
How hard was it to do? One of my boxes is starting to make a bit of noise.
Old Aug 31, 2008 | 03:24 PM
rustysavage's Avatar
Im have the bearing issues as well with about 65k on mine. do you need to find someone with a press to install the new bearings?
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
Jordly221
Feb 13, 2019 05:29 PM
xdejablu3x
Apr 19, 2017 03:44 PM
zom6iemac
Nov 28, 2014 12:28 PM
