CAI check engine light back on
Old Aug 14, 2008 | 10:42 PM
jcortes's Avatar
Default CAI check engine light back on
I had posted earlier about my check engine light being on after installing my Injen Cool Air Intake and I got the light to turn off by resetting the ECU but after a little bit of driving it came back on. I was reading another post and they said to reset the ECU and let it idle for like 15 mins. By idle to they mean just let it run with the engine on in the driveway? I also took it to Autozone but they don't to CEL tests anymore. Any help would be great thanks.
Old Aug 14, 2008 | 10:51 PM
Scott8's Avatar
idle as in just let it run like you are warming up your car. Any issues with the install?
and I think I asked in your other thread, but did you make sure it was the correct year for your car? All sensors and plugs are plugged in correctly????
Old Aug 14, 2008 | 10:52 PM
ack154's Avatar
Autozone doesn't do CEL tests anymore? Go to another Autozone, man. Yes they do...
That's probably the only way we're going to be able to help... you have to get that code(s). You said you tried cleaning the MAF, resetting the ECU, etc... those are the typical things. You could have a damaged MAF.. but it's hard to say.
Old Aug 14, 2008 | 10:54 PM
jcortes's Avatar
Ya install was good. I did drive once without the wires hooked together from the old intake but once i plugged those in things where fine. I will try to reset the ECU and let it idle for a while because before i was just resetting it and taking it for a drive right away. I drive kinda rough so it could be confused.
Old Aug 14, 2008 | 10:55 PM
jcortes's Avatar
They don't they got in trouble for it by the dealers. Just recently happened.
Old Aug 14, 2008 | 10:58 PM
Scott8's Avatar
how they get in trouble by the dealers??? Sounds like the car dealerships miss charging an arm and a leg for a scan....
where you live? maybe someone with a scanguage can help you out
Old Aug 14, 2008 | 11:02 PM
jcortes's Avatar
I live in orange county california. They have them them for sale at autozone but they don't do free testing anymore.
Old Aug 14, 2008 | 11:04 PM
jcortes's Avatar
would something like this tell the problem
http://www.amazon.com/exec/obidos/AS...esearch5356-20
EDIT:
or this
http://www.amazon.com/Actron-CP9125-...ion/B0007LEG2K
Old Aug 14, 2008 | 11:08 PM
Scott8's Avatar
a scan guage will tell you the codes.
if you buy one, get it in the vendor classifieds from 365Motorwerks for $154.95 shipped
Old Aug 14, 2008 | 11:56 PM
engifineer's Avatar
or you can just buy a code reader for about $35 Auto parts stores sell them, sears has them, etc.
There is no way autozone got in trouble from the dealers, if they say that they are full of it. the emissions info on OBD2 is generic and HAS to be by federal law. They just wanted to sell you something.
What year is your car?
What year models is listed on the intake info? They changed the intake for the 07's and up, so an 05-06 intake will not work properly on an 07 and up.
If you pulled a vacuum line off the VSV (mounted to the intake) when you did the install, it will be throwing an evap code. If you dont have the MAF seated correctly, it will throw a code for that.
Old Aug 15, 2008 | 02:48 AM
jcortes's Avatar
One of the hoses on the VSV was pinched. I took some pictures to show what I mean
the first one is the picture of the valve itself
the second is a picture of the pinched hose
and third is the picture of how I have it attached to the air intake.
How am i supposed to attach it without it pinching the hose.
Old Aug 26, 2008 | 01:23 AM
jsingh's Avatar
OhioScions
did u figure out the problem yet!!
Old Aug 26, 2008 | 01:54 AM
crush02342002's Avatar
may be that will help a little.
Old Oct 1, 2009 | 07:53 AM
v-train's Avatar
____ now im scared to put my intake on
Old Oct 1, 2009 | 02:03 PM
GQQSE13's Avatar
wtf? put your intake on!!!!! i've had mine for 2 years, others have had theres for 4-5 years and it doesnt do a damn thing. if you get a CEL, un hook batt terminals for 10 min, put back on and drive away as it resets the CEL and you're good to go. i'm over 30k miles w/ mine and no CEL
Old Oct 2, 2009 | 03:01 AM
charlie07tc's Avatar
if you get the maf code, just put a bead of clear silicone around the maf where it contacts the intake.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
ScionRo
Jan 2, 2015 07:54 PM
