Help with vent controls
Old Aug 15, 2008 | 03:58 PM
mikee1680's Avatar
Default Help with vent controls
My car got broken into like a week ago. The center console was ripped off. I put it back together, but, found out I can't control the direction of air flow. When I turn on the ac, no air comes out of the two front vents near the radio. The only cables I found were for hot or cold air. Isn't there supposed to be more cables? Help!
Old Aug 15, 2008 | 04:00 PM
mikee1680's Avatar
This is my only picture. I only see two cables.
Old Aug 15, 2008 | 04:50 PM
burstaneurysm's Avatar
No, that looks right... did you make sure you put the ***** on the right posts?
Old Aug 15, 2008 | 04:52 PM
dmaul1397's Avatar
I guess I just dont really understand your question... The three plugs that I circled are the three for the HVAC controls.
Old Aug 15, 2008 | 05:24 PM
mikee1680's Avatar
I'm not sure if it's supposed to be a cable or wire. I can't seem to control where the air comes out.
Old Aug 15, 2008 | 05:58 PM
cherry-8's Avatar
The air flow is controlled by two cables in a housing like the brake cables on a bicycle. The end of one cable is clamped onto the back of the defroster damper control , the other is clamped to the back of the air mix damper control (Left **** and right slider switch for circulating/recirculating air).
check out pp 55-25 - 55-27 of the manual.
HTH,
MD
Old Aug 15, 2008 | 08:24 PM
mikee1680's Avatar
HTH,
MD
Got it! Thanks man! I made it more complicated than it should. I expected more than two cables to control air flow and air temp.
Old Aug 15, 2008 | 09:23 PM
cherry-8's Avatar
HTH,
MD
Old Aug 15, 2008 | 10:24 PM
bB2NER's Avatar
Music City Scions
Here is a link to the factory service manual. It will show which cable does the temp and which one controls the blend doors. Good luck straightening it out and sorry that someone did that to your box.
http://www.myjdmphoenix.com/images/04_xB_Repair_Manual/
Old Feb 4, 2022 | 05:53 PM
sallyTe's Avatar
Problem 1) My 2008 xB vent control **** won't turn all the way to defrost.
Problem 2) I bought the car used, I notice that the AC fan is always on, seems that someone had changed & re-directed the wires.
AC is cold when driving, but not cold on idle.
Old Feb 5, 2022 | 11:30 PM
04_Toaster's Avatar
Dunno, mine is 1st gen.....maybe someone in 2nd gen section can help. Either way sounds rigged and some wiring needs to be fixed and probably the cables that control the air routing.
grizzenbox
Mar 31, 2012 06:18 AM
sefalik
Scion tC 1G ICE & Interior
Oct 24, 2008 09:48 PM
cingham
Jul 27, 2008 05:27 AM
monkeysauce
Apr 27, 2007 11:22 PM
Xonic
Nov 5, 2004 10:51 PM
