Fiberglassing supplies
Old Dec 15, 2004 | 06:31 AM
djct_watt's Avatar
Team Sushi
Default Fiberglassing supplies
I need help from anybody with experience in fiberglassing. . .
1) Where is a good place to buy fleece (for a good price) to lay the first layer of resin?
2)How much resin/hardener do you think I'll need to cover the under floor compartment of the xA?
3)Do you have to resand to fiberglass over an area that has already dried, or can you just glass over it (I want to build it in 2 pieces)?
Other than that, I am set. Any help would be greatly appreciated!
Old Dec 15, 2004 | 06:53 PM
Big_Jim's Avatar
i can help on the fleece. go to any local fabric shop and see what they got in thier clearance section. igot plain white fleece for $1.50 a running yard. and its 60"s wide.
got alot of fleece, for little money. just a thought take a look into it.
Jim
Old Dec 15, 2004 | 07:03 PM
TheScionicMan's Avatar
Don't know about price, but TAP Plastics has a lot of that kinda stuff...
Old Dec 15, 2004 | 07:20 PM
squirrel's Avatar
Default Re: Fiberglassing supplies
TAP Plastics and Home Depot has a good assortmnent of mat and fibre. Some hardware stores also.
You will definitely need at least a gallon of resin if you plan on doing the floor and in more than one layer. If the mold you are using is smooth, then you will not need to sand it before painting. The plus to fibreglassing is you can add layers w/o any prep once the first layer is cured.
Make sure you add the right amount of hardner to the resin or it will take forever to cure.
Old Dec 15, 2004 | 07:24 PM
squirrel's Avatar
If I knew more about what you plan to fibreglass, I could give you some more info.
Old Dec 15, 2004 | 07:38 PM
VtScionGuy's Avatar
You could also use Bondo to smooth things out...
For fleece a cheap way would be to use old sweatshirts, usually the bottom layers are made using the fiberglass mats used in kits first to build stronger layers
Buy extra hardener and apply liberally if the space you're working on is large and easy so that it'll harden faster, but if you too slow then find a new bucket, muhaha
Old Dec 15, 2004 | 07:49 PM
Mark44's Avatar
Go to this place, they have everthing you need. I am into freestyle jet ski and do glass work all the time.www.shopmaninc.com
Mark44
Old Dec 16, 2004 | 02:18 AM
djct_watt's Avatar
Team Sushi
THANKS!!!!
Old Dec 16, 2004 | 09:11 PM
squirrel's Avatar
THANKS!!!!
Did everything work out?
Old Dec 16, 2004 | 11:12 PM
djct_watt's Avatar
Team Sushi
Got my supplies. . . I start glassin on Monday
Old Dec 16, 2004 | 11:17 PM
AudioFormz's Avatar
ALWAYS sand each layer of fiberglass prior to applying the next! This is the weakest link and if you do not sand (80 grit or so), the layers can split apart! I have seen it done many times. Only takes minutes so why not do it right!
www.selectproducts.com carries alot of fiberglass materials for audio applications. I have quite a bit myself so I may be able to help you or anyone out that is looking for fiberglass materials.
Old Dec 17, 2004 | 12:00 AM
Ashe_WCM's Avatar
DeepSouth Scions
Do what I do, go to Marine supply stores. they always have fberglass stuff.
XB06
15
Oct 1, 2022 10:24 PM
Wrencher
Jul 29, 2015 03:51 PM
lunchbx05
May 7, 2015 06:42 PM
CONCRETETC
Feb 9, 2015 08:05 PM
Max2k
Jul 14, 2004 08:02 PM
