dynomat or Hushmat Install
Old Aug 20, 2008 | 03:59 PM
mtaylor's Avatar
Default dynomat or Hushmat Install
I have a little over 55 Square feet of hush mat and wondering if that is enough to do the box. In process of building monster system. I at least want to do the doors heavy and the hatch. The roof would be nice but i want to make that box not able to make sound outside car.
Old Aug 20, 2008 | 06:38 PM
randomsuper's Avatar
no way that's enough. i used about 100sq ft on mines and that barely did it. some areas were a little thin.
Old Aug 22, 2008 | 12:33 AM
redline8k's Avatar
I used 120sqft of second skin, I did the whole car top to bottom. I would recommend doing the floors and the rear tire areas more...
-nick
Old Aug 22, 2008 | 07:23 AM
brentw59's Avatar
I used 2 shop packs of second skin. It came in 5 different boxes. I used 1 box to do 2 layers on the whole roof and then 3 layers down the seam in the middle. I only did 1 layer on they larger walls, trunk, spare tire, and back hatch. There will be rattles no matter how much sound deadening the wing if you have one the trim piece acrost the back. The back hatch will flex. Oh dont forget to seam seal the cross braces on the roof again. The stock seam sealer is weak so you need to use more than just spot here and there on the slats. Once I did the roof on mine along with the seam sealing I notice the car felt more rigid and sturdy. Tells about the system you want to put in. I have got a few friends already hitting right at 150db in there gen 2 xB.
Old Aug 22, 2008 | 04:14 PM
spiderxB's Avatar
How much weight does this add? I am trying to avoid causing a decrease in fuel efficiency due to weight.
I was considering using a liquid type dampener such as spectrum sludge from second skin. It is supposed to be half the weight and get into places that are hard to get to with mats. Any experience with this?
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
