View Full Version : removing fog lights?
smokyXB
12-15-2004, 04:05 PM
i just need some point of direction on how to remove my fog lights. i got my dealer installed ones and the tech section shows how to pop that plastic peice out. can i just "pop" out my fog lights? they seem to be in there pretty good..
THE_DON
12-15-2004, 05:16 PM
Yup... Just like most of the parts on your Scion, they just pop off.
Try using a flat head screw driver with a soft cloth on the end and make sure you 'pop' them from the inside(middle of bumper) out.
-THE DON
smokyXB
12-15-2004, 05:19 PM
ima go try now, thanks
Joehnn
12-15-2004, 05:20 PM
Let me know if it works OK. I'm going to pop mine out to put yellow bulbs in.
TheRedBox
12-15-2004, 05:21 PM
becareful not to scratch your paint....
Yellow bulbs are sick!! i got the PIAA ones
smokyXB
12-15-2004, 05:24 PM
how do you get into the inside?
Joehnn
12-15-2004, 05:33 PM
I think he means between the bumper and the light on the edge closest to
the middle of the car.
THE_DON
12-15-2004, 05:34 PM
To take them off? You don't need to. I guess you could reach down from the engine bay to pop them off, but you don't even need to pop the hood to remove them. Just pry them off from the outside. By 'inside' I mean pry from the side of the lens that's closer to the license plate.
Once they're off you just disconnect the bulb or remove the wire harness. I put Silverstars in mine to match the headlights. Much brighter now!
-THE DON
smokyXB
12-15-2004, 05:42 PM
okay i got them out but i noticed a small scratch on my paint about 3 inches above it i dont know if i did it but now i dont feel good :roll:
Joehnn
12-15-2004, 05:49 PM
That's a _____. :(
He did say wrap the screw driver with cloth.
Hopefully its an easily repaired scratch.
smokyXB
12-15-2004, 06:21 PM
yeah i think it went thru the sock i used, im going to try and buff it out if not im gonna goto a body shop, my mom LEANED ladder on my car and it fell and scracthed the back a little about 5 months ago, that needs to be fixed although u cant see it unless i point it out :x
TheScionicMan
12-15-2004, 06:47 PM
I wouldn't remove them to change the bulbs. It's kinda a PITA to get the harness with bulb attached back thru. it's quite simple to change the bulbs with them installed. Just reach up under the bumper on the driver's side and go down thru the engine bay on the passenger side.
