View Full Version : JDM Parts
Kendo 01-16-2004, 07:20 PM Here are some images of the JDM mirror covers with LED blinkers with the "rain clear" blue tinted glass as well as the brushed aluminum "bB" rear view mirror cover and "bB" stainless door sills.
http://members.cox.net/inazuma/images/wheels%20011.jpg
http://members.cox.net/inazuma/images/wheels%20019.jpg
http://members.cox.net/inazuma/images/wheels%20012.jpg
http://members.cox.net/inazuma/images/wheels%20010.jpg
TheRedBox 01-16-2004, 07:27 PM Nice stuff. I wanted those mirrors.
Kendo 01-16-2004, 07:30 PM Fitment on the passenger side was perfect. The driver side however needed to be modified. The back side of the JDM glass on the driver side mirror doesn't match up with the US Spec mirror for some reason so some tabs had to be clipped off in order to be able to adjust the mirror at it's full range.
XBBOY 01-16-2004, 07:46 PM Those look nice Kendo...I believe Crystal from TSW has those side mirror covers and they look awesome..."I needz me dem covers". Your car is look great nice job.
randode 01-16-2004, 08:07 PM Those look nice Kendo...I believe Crystal from TSW has those side mirror covers and they look awesome..."I needz me dem covers". Your car is look great nice job.
they are getting painted right now :D
Inazuma 01-16-2004, 08:15 PM hehe kendo...
I like the blue glass pic with my xB in the background..
I did not know you took that pic when u had my camera..Nice Pic..hehe
where to buy some of these jdm parts ---- here from the sl site or are there some other importers i was thinking of the ts mirrors but i havent made up my mind just yet as im awaiting delivery of my xb they look great but is it just black plastic or can you get them painted ???
thanks
chad
Kendo 01-16-2004, 09:18 PM I picked up the JDM badges, door sills, rear mirror cover, blue glass mirrors, and the blinker side mirrors from Steve at Carson Toyota/Scion. I ordered the mirrors prepainted in black to match my xB's color. They come unpainted, or you can order them prepainted.
Mr_scion 01-16-2004, 09:29 PM you can get that here
http://newscionparts.com/
its_ikon 01-16-2004, 11:54 PM those products look sweet.
i found them on another post ill have to keep that in mind thanks i do like some of the parts i did notice that the sig morrors look different then the ones posted on the photo above
HotBox 01-17-2004, 08:20 AM damn going jdm huh niceee
i really like this pic its very cool
Munch 01-17-2004, 12:40 PM http://members.cox.net/inazuma/images/wheels%20011.jpg
I'm getting those mirrors :D
Kendo 01-19-2004, 08:30 PM The install is pretty straightforward, but the instructions were in Japanese.
Basically, it involved:
1. Disconnect the negative terminal of the battery
2. Remove side mirror glass (Mask off the bottom portion of the mirror housing and then pry the bottom part of the mirror off. It snaps in in two spots on the bottom. There is also some white adhesive goo on the back that you will have to deal with)
3. Remove Door Panel (have your windows rolled down as well)
4. Disconnect the plug for the mirror motors
5. Pull the black triangular cover off of the inner side of the mirror
6. Remove the 3 nuts holding the mirror on and remove the mirror from the car.
7. Remove the 3 torx screws on the bottom of the mirror and remove the 1 philips head screw holding the rubber piece that seals the mirror.
8. Drill a hole in the factory mirror housing just above the mirror motor. The instructions called for a 8mm hole. I think I did mine only at 7/32 though. I started with a small pilot hole and made it just large enough to get the wiring through.
9. Attach the LED portion to the inner side of the mirrors.
10. Feed the wiring from the LED unit through the drilled hole and run it along the same route as the factory wiring for the mirror motor.
11. Attach the blinker mirror cover to the factory mirror housing. (Make sure the factory mirror housing is clean before attaching the JDM cover)
12. Reattach the mirror glass, 1 philips head screw holding the rubber piece that seals the mirror, and the 3 torx screws. Then reattach the mirror to the car.
13. Slide the rubber protective tubing over the wires and attach the supplied connector to these same wires.
14. Pop the side marker out of the fender. Connect the supplied T-connector wire harnass to the wiring for the side marker.
15. Feed the long end of the T-connector wire harnass through the back side of the fender and UNDERNEATH the weather strip of the front door. Use the supplied foam tape to secure the wire at the point BENEATH the weather strip.
16. Connect the end of the T-connector wire harnass to the connector attached to the LED blinker mirror cover.
17. Clean up the extra wiring length using supplied zip ties and secure them down neatly.
18. Put the door panel back on and reconnect the battery and you're done.
19. Install procedure is the same for both sides.
Inazuma 01-19-2004, 10:44 PM damn going jdm huh niceee
HOTBOX--
you probably like my xB in the background huh? :lol:
Kendo 01-19-2004, 11:10 PM Nah dude, it's the blue tinted mirrors not your ride... lol =Þ
HotBox 01-19-2004, 11:26 PM its not ur ride or the blue tinted mirror its the scenery jk
Inazuma 01-20-2004, 12:33 AM :cry: just kiddin
philip 06-25-2004, 06:58 PM you can get that here
http://newscionparts.com-will the jdm rear spoiler fit the xb with no modification?i noticed the jdm spoiler only sells for $172 while the non jdm is $242.
TheScionicMan 06-25-2004, 07:33 PM I like the lights on the top - That's hella JDM... :lol: :lol: :lol:
socalxb 06-26-2004, 04:57 AM Guys -
What's the tire/wheel and spring combo on those xB's in the pictures, especially that white one?
The white one looks slammed, and the dark one not as much.
